Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | S6
Old 11-05-2018, 05:31 PM
PatrickCusack PatrickCusack is offline
Default Send pages on layout change
I have a mixer who is going from layout A to layout B and back to Layout A in strip mode. They use send page 2 on Layout B. Whenever they go to Layout A, they would like to return to send page 2 on Layout B. Is this possible? Maybe possible to send all the strips in a layout to page 2 via one key?
Patrick
18.3 and 2018.3+
Old 11-05-2018, 06:18 PM
creativecontrol's Avatar
creativecontrol creativecontrol is online now
Default Re: Send pages on layout change
Greetings,
Assuming you've explicitly saved the function view (Sends) and page for the strips before saving the Track Layouts, this should recall 100%. I just tested this (although on a newer version of S6) and it works perfectly: 3 different Track Layouts with 3 different pages of Sends stored and recalled.
If you enable the ALL switch you should be able to press any channel's page switches (while in Sends view) to jump them all.
Jeff
Jeff Komar
Old 11-14-2018, 10:35 AM
Apologies Jeff,
Can you explain how I save the view function with the layout? Are you saying that I can save an EQ view with a layout, and a send view with another layout?
Patrick
Old 11-14-2018, 11:13 AM
Definitely. Simply create or recall an existing Layout. Make changes to function views (EQ, Dyn, Sends, etc. - plus the desired pages you want them to be on. Optionally change any individual display module views for the associated tracks.
Last, make sure the Ignore functions on layout recall preference is not ticked if you want the layouts to change the function views.
Store your changes to the desired layout locations.
Jeff
Jeff Komar
Change font color on softies pages? Frank Kruse Pro Tools | Control 2 04-25-2018 02:08 PM
Send A-E bus assignments change colour SweetSoulSound Getting Started 3 06-11-2014 12:53 PM
Change horrible Pt 11 layout on Windows? theclassicguy Pro Tools Software (Win) 21 04-26-2014 05:00 PM
MC-Pro How To Change from English to German Keyboard Layout? moacito System 5 1 01-30-2013 08:20 AM
how to change Rev and Chor Send of my CS6R from PT vudoo MIDI 3 03-31-2001 05:22 AM
