Old 08-22-2012, 09:11 PM
RCN RCN is offline
Default How to properly connect Apogee AD-16x
Hello, just picked up a used AD-16x and want to know the correct way to connect to my PT HD4 accel sys/ Magma pe6r4-1..
I also have a 192 and a 96 i/o..
So, I'm thinking I connect the digi link cable from the HD core card to the Ad16, then to the 192, to the 96.. and then connect the bnc to all 3 too, correct?
Also, do I need a "Wide Eye" for the Apogee or just a regular bnc cable?
Thanks for your help guys...
Old 08-22-2012, 09:14 PM
RCN RCN is offline
Default Re: How to properly connect Apogee AD-16x
btw, the Apogee does have the X-HD Card installed..
Old 08-23-2012, 12:30 AM
JFreak's Avatar
JFreak JFreak is online now
I think you need to set the Apogee as clock master, then feed the clock signal to your 192 loop sync input and again route that to the 96 interface's loop sync. I would guess you shouldn't route the loop sync back to the Apogee (which is not Digi interface) but I might be wrong about this so test it and keep the configuration that works...
Janne
Old 08-23-2012, 09:49 AM
RCN RCN is offline
Yes, I will set the Apogee as clock.. Are the connections correct? I should have this unit tomorw, anyone out there with an Apogee XHD Card set-up?
Apogee Rosetta 200 (MINT), Lynx AES16e-SRC, Apogee Duet, BBE 882i, OFFERS ENTERTAINED jrhager84 Buy & Sell 5 03-11-2013 01:25 AM
Apogee Thunderbridge to connect AVID HD I/O? producerdna Pro Tools HDX & HD Native Systems (Mac) 1 03-04-2013 08:31 PM
Need advice on how properly connect my monitors to a Control 24 sonixstudio Pro Tools TDM Systems (Mac) 2 08-19-2011 01:02 PM
How to connect monitors from the apogee Rosseta analog out to Control 24 Jorgi's ICON & C|24 0 10-27-2010 10:36 PM
apogee rosetta connect ? radioface 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-22-2003 04:54 PM
