Old 11-24-2007, 12:11 PM
mboxpro mboxpro is offline
Default Best way to power supply a Mbox 2 Pro
Hi everybody, time to connect my mbox 2 pro to my powermac mdd.
The mbox 2 pro is connected to the powermac with a firewire cable that transmits the data flow and also feeds the mbox 2 pro with the supply needed.
My mbox 2 pro becomes with an external wall mart power supply that I think that could be better that the poor firewire power supply. So my question is very easy: What is the best way to feed the mbox 2 pro???? By the firewire cable or by the external wall mart?????
As soon as I connect the firewire to the mbox 2 pro the firewire port feeds the unit with the power supply, so I have another question: If I wants to connects the mbox 2 pro to the external wall mart, need I to replace the 6 pin firewire cable with a 4 pin to not to feed the mbox 2 pro from the firewire port????? or maybe could I leave the 6 pin cable and the mbox 2 pro swap itselfs the power supply from the firewire port to the external wall mart, living togheter both kinds of power supply??. In that case which power supply is selected for the unit?????
My last question is about the quality needed on the firewire cable. Is a real matter the quality of the cable???? for example is any improvement if I use a Monster firewire cable rated 40 dollars versus a belkin 10 dollars cable????
Thanks on advice and sorry for my poor english, I´m not a native english speaker.
Old 11-25-2007, 03:37 PM
Default Re: Best way to power supply a Mbox 2 Pro
Anybody??
Old 11-25-2007, 04:14 PM
Mr. Anderson Mr. Anderson is offline
You're waaaaaaay over-thinking this. Use whichever method works best for you.
Old 11-25-2007, 10:49 PM
Goobs's Avatar
Goobs Goobs is offline
Are you planning on using condenser microphones (that require phantom power?)
This may help to make your decision for you.
Good luck,
Jeff
iMac (Retina 5K, 27-inch, Late 2015), 4.0 GHz Intel Core i7, 32 GB 1867 MHz DDR3, 500 GB Flash Storage SSD, macOS 10.14.6
Pro Tools|Ultimate 2020.5, Logic Pro 10.5, Nuendo 10.3, Cubase Pro 10.5, Reason 11.3, Live 10.1, Digital Performer 10.11, Studio One 5, Waveform 11.0.26, Reaper 6.08, WaveLab Pro 10.0.40
Waves Horizon/Diamond 11.0.58, Melodyne 5, iZotope Post Production Suite 4, iZotope Music Production Suite 3, Soundtoys 5.3
Apogee Quartet, Eleven Rack, 003, Command|8, OWC Thunderbolt 2 Dual-Drive Dock, OWC Mercury Electra 480 GB 6G SSD, OWC Mercury Elite Pro 250 GB 7200 RPM HDD
Old 11-26-2007, 01:54 AM
yes I will use condenser mics
MBox 3 Pro power supply replacement A Ross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-04-2011 10:46 AM
Mbox 2 power supply question dalebu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-14-2010 07:28 AM
Where to Purchase an MBOX Power Supply MR4 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-04-2008 01:10 PM
Mbox 2 Pro power supply in europe? solosound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-11-2006 10:41 PM
MBox Power Supply WheelSpoke 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-11-2002 09:23 PM
