Go Back   Avid Pro Audio Community > Legacy Products > ProControl, Control|24, Command|8
Old 05-26-2017, 12:11 PM
Papacoyote Papacoyote is offline
Default Is it possible to join a Procontrol with an 003?
Just got a Procontrol And was wondering if it's possible to join it with my 003 rack?
I searched and found no info on this...
Thx, rd
Old 05-26-2017, 06:24 PM
Top Jimmy's Avatar
Default Re: Is it possible to join a Procontrol with an 003?
The ProControl was meant for use with Pro Tools HD. If it's not available in Setup>Peripherals>Ethernet Controllers, then you can't use it with the version of the software that you have.
James Cadwallader
Old 05-26-2017, 06:46 PM
Thx...
Old 05-27-2017, 12:43 PM
Neil H Neil H is offline
That is absolutely not true!
Pro Control will work with non HD Pro Tools, if you don't have the controller profiles in the controllers folder or the DigiNet ethernet protocol installed then it wont show up but I can give you the right files if you need them and yes it can be used with the 003.
Pro Tools 2019.5 Ultimate
Windows 10 Pro
Join the Facebook Pro Tools Windows User Group
Old 05-27-2017, 02:11 PM
Top Jimmy's Avatar
Thanks for the clarification. If it doesn't show up in his peripherals setup, then I expect that he does need the profile and protocol.
James Cadwallader
Old 05-27-2017, 02:34 PM
There appears to be an echo in here
Windows 10 Pro
Old 05-29-2017, 08:13 AM
One important detail the OP let out is what version of PT he is running. Pro Control does not work at all on Pro Tools 11 or later.
Join into Stereo? Starting User macOS 3 07-31-2013 06:18 AM
Should i Join the Union? myke2242 Post - Surround - Video 35 05-10-2012 10:09 PM
Join the contest Stiff General Discussion 0 04-09-2009 02:00 AM
What does the "Auto Join" tab do? abbyin3d Pro Tools TDM Systems (Mac) 4 01-18-2006 07:39 AM
