Re: "MOVE UNAUTHORIZED PLUGINS: Pro Tools could not load the following plugins..."
We'll need more details to help... Pro tools version Operating system Which plugins specifically What troubleshooting steps have you taken already? Re installed ilok manager have you tried sync repair in the ilok manager then re auth the licences to the ilok Trashed prefs Repair disk permissions Chris
So I will take that as a no...LOL
ProTools 10HD OSX El Capitan 10.11.4 It seems to be all of the RTAS plug ins. I have manually uninstalled (yes I got ALL the necessary files) ProTools and re-installed it, as well as iLok Manager. I have trashed preferences, it still gives me the error when starting ProTools. I have not repaired disk permissions. What is the process for that? -Andy |
Pro Tools 10 is not qualified for OSX 10.11. That may be the problem.
Could be...but is that the answer? I think other people have used them just fine. I mean, I will probably use better plug-ins anyways, but it is always nice to have more in my arsenal.
Anyone figure this out? Just came across this issue installing PT 10 and 12 on a new machine with 10.11.5.
Avid rtas plugins showing this error, but all third party rtas are working fine. |
#16
As Werner said above - PT10 is not, and never will be, qualified for ElCrapitan. To even get PT10 installed the installer would have to be modified and then there's the well known graphics issues like missing entries in the inserts until you hover over them.
#17
Yes I'm well aware of the fact that it is not supported and there are some graphical glitches. Been running 10.3.10 on Yosemite for some time now on another one of my machines with no issues.
Just wondering if anyone has solved this issue. |
#18
I seriously doubt you had no issues with Yosemite unless you don't count the known issues people have posted here issues for you. Thing is you're trying run a totally unsupported system so don't expect things to work right if at all. Of course if you have Patchwork or MB7-2 you could run the vst or au versions of your non-Avid plugins in there and thence in PT.
#19
Other than the graphical glitches, which I've really gotten used to at this point, nothing show stopping. Same with el capitan besides this really odd issue.
Again, yes I totally understand its unsupported. Just wondering if someone here has found a way around this particular bug. |
#20
PT 9.0.2 "loud pop and No Sound" problem related to plugins and 002R | bortraws | macOS | 18 | 08-17-2015 03:21 AM |
"this action can cause loss of plugins in Pro Tools" after renaming a drive | Terry Wetzel | Pro Tools 9 | 4 | 05-01-2015 02:47 PM |
Removed waves plugins, now getting prompt saying "locate" folder | remusjacobs | macOS | 1 | 07-25-2012 06:15 PM |
Pro Tools 9 "Quits Unexpectedly" on start, when loading Plugins! | dbC4G | macOS | 6 | 04-06-2012 05:51 AM |
Message "Pro tools with tdm requires the tdm mixer plug-in in the plugins folder" | Alexei Zaitsev | Pro Tools TDM Systems (Win) | 0 | 01-10-2009 03:48 AM |
