#101
Re: Pro Tools MTRX
Yes - that should be listed as 1500x1500 not 384x384. I will let them know. MTRX can be clocked several different ways including Word Clock. If you have a SYNC HD you can feed Word Clock out into the MTRX input. You can set DADman to adapt Sample Rate to Pro Tools via DigiLink. You can also use an external clock DA if you have a more complex setup to distribute Word Clock to all of your converters and external digital devices.
Jeff |
#102
Re: Pro Tools MTRX
https://lukehoward.com/ |
#103
Re: Pro Tools MTRX
If you are using the SYNC HD currently to resolve your system to SD or HD Video Ref I would keep the SYNC HD as the master and feed Word Clock into the MTRX while continuing to distribute Loop Sync between the SYNC, OMNI and HD IO.
If you don't need to resolve to Ref, I would set the MTRX as the Master -> Synchronization: Internal and feed Word from the MTRX to the SYNC HD Word in while continuing to Loop Sync between your SYNC HD, HD OMNI and HD IO. Jeff |
#104
Re: Pro Tools MTRX
In any case, the second scenario should work for most of my use cases. I suppose I could feed WC from the SYNC to the MTRX to cover the first scenario and WC from the MTRX to the HD I/O, and loop sync all the Avid I/Os. In theory I can switch between the use cases in software (even if not purely within PT).
#105
Re: Pro Tools MTRX
Wow, that's nice :)
#106
Re: Pro Tools MTRX
BTW can someone from Avid explain how Loop Sync is terminated? Is it at the master device?
#107
Re: Pro Tools MTRX
Here's a document that talks about Loop Sync, defining a Loop Master and integrating external clock sources. It is a bit dated but still relevant.
http://akmedia.digidesign.com/suppor...tter_30957.pdf Best, Jeff |
#108
Re: Pro Tools MTRX
Anyway, when my MTRX arrives, I will try a few things and report back.
#109
Re: Pro Tools MTRX
It isn't. As the name implies, it is a loop. Don't break it!
#110
Re: Pro Tools MTRX
Sorry, I meant electrically, not physically in terms of cabling (if that makes sense).
