Old 11-03-2011, 11:17 AM
Cary_Clark Cary_Clark is offline
Default HD Omni configuration
Hey guys,
I am considering the purchase of some new gear and had a couple quick tech questions. With the HD Omni can I run 16 channels of AES (optically) in and 8 channels of analog out symiltaniously? The Omni has the connections to do so but the user manual makes it look as though it is a maximum 8in/8out unit. Is it possible to configure it for 16in(AES Optical) and 8out (analog)?
Old 11-03-2011, 12:45 PM
Picture Start Picture Start is offline
Default Re: HD Omni configuration
You cannot mean "AES, optically" as AES/EBU doesn't run on anything but 110 ohm XLR-terminated cable.
You can run 8 in and out simultaneously with an OMNI, plus a dedicated stereo cue mix. For anything more, you'll be better served with an HD I/O 16-channel digital option.
Old 11-03-2011, 12:54 PM
nst7 nst7 is offline
Correct. It's a total of 8 in, 8 out, regardless of if it's analog or digital. Plus the hardwired headphone cue mix out (stereo).
Old 11-03-2011, 01:50 PM
Thanks guys. Yeah I ment optical input not AES I get my digital signals crossed every now and then.
Old 11-03-2011, 01:54 PM
The Omni does allow for 8x2 Optical in though correct? But if I configure this way I will loose my 8 analog outs?
Old 11-03-2011, 05:31 PM
Bill Denton Bill Denton is offline
Actually it's 8 optical in, period. The second optical port is for SMUX, which allows you to send sample rates greater than 48K by sending 4 to each optical port.
But no matter what, you only get 8 ins and 8 outs. You can mix and match analog and digital, but you can only use a total of 8 ins/outs.
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Omni vs HD 8x8x8 io and Omni Pre's Southsidemusic Pro Tools HDX & HD Native Systems (Mac) 13 03-27-2013 01:00 AM
OMNI Fried? Calling Omni Members - Check High Samplerates KingFish Pro Tools TDM Systems (Mac) 3 11-03-2011 09:19 PM
Be aware! Potential HD Omni buyers with treated Rooms and Computers. Omni Noisy Fan FRaNCo MuSiC Pro Tools HDX & HD Native Systems (Win) 0 09-25-2011 05:42 AM
PC Configuration milesyoung 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-09-2002 07:14 PM
PC Configuration ChrisMc73 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-14-2001 08:43 AM
