OMNI physical I/O question (inserts)
Maybe somebody can confirm this for me.
I have an Omni and am trying to get my head around the monitor section and the way it affects being able to use the other outputs. What I would like to do is have a 5.1 monitor output, BUT I also want 2 channels to be assigned to hardware inserts to send my recorded tracks and return them in the normal way. It seems that with the 5.1 monitor enabled, I cannot use the 4 physical analog outputs as insert sends. The other thing I discovered is that if you have a monitor path of any width, you cannot move it around from, say, channels 3-8, leaving channels 1-2 free. So how can I have 2 channels set up for hardware inserts? I can think of two ways, but I don't have the unit with me now so I can't fiddle with it at the moment: 1. Disable monitoring altogether. I believe I can set the MAIN and ALT monitor paths each to "none". If I do this, does the I/O act like a normal Pro Tools interface? I figure if this is the case, I can assign my 5.1 out to 3-8 and set up hardware inserts for 1-2. 2. I had this thought just now: In the HARDWARE window, you have the MAIN tab. Can I assign the physical inputs to any pair I like? In other words, the thing that's causing me from having an insert on 7-8 is that he OMNI only has 4 analog inputs, called Analog 1-4. In the MAIN tab, can I assign Analog inputs 3-4 to the fourth pair of input registers? Check out this screenshot (I'm borrowing it from some threat at Gearslutz—only one I could find on Google Images): See how on the INPUT side, there are 4 pairs (inputs 7-8 are assigned to ADAT 1-2)? Can I assign 7-8 to "Analog 3-4" so that I can make an insert by using Analog 7-8 to go out to my gear and back in with Analog 3-4? See what I mean? |
Did I make this too hard to understand?
Re: OMNI physical I/O question (inserts)
How about setting up a 7.1 output monitor path and then in your I/O split them into a 5.1 and a stereo pair?
I don't think it works that way. Monitor paths can't share!
OK, sad that I had to answer my own question, but yes, you can make inserts in the I/O Setup on 7-8 by assigning physical inputs Analog 3-4 to PT channels 7-8 and it works while using a 5.1 monitor.
OMNI inserts only for mic pre , or used as master buss inserts as well | Weird Audio | Pro Tools TDM Systems (Mac) | 3 | 11-14-2012 09:27 PM |
Omni question | Craig F | Pro Tools TDM Systems (Mac) | 5 | 01-30-2012 12:39 PM |
Compressor with Omni - Inserts or Patchbay? | Cliffy_Boy | Pro Tools TDM Systems (Mac) | 6 | 11-28-2011 11:09 AM |
D-Show Physical Configuration Question/Poll | apco25guy | VENUE Live Sound Systems | 8 | 09-10-2009 09:33 AM |
Delay in physical inserts on Digi001? | zboy2854 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 06-19-2001 06:26 AM |
