Old 04-07-2009, 01:53 PM
10onpump7's Avatar
10onpump7 10onpump7 is offline
Question Unable to locate M-Audio hardware??
every time i try to open PT it says Unable to locate M-Audio hardware, I just installed a ProTools demo i received with my Fast track Pro, I have the interface, and a Axiom49 installed hooked up and turned on. What could the problem? Help plz...
Old 04-07-2009, 05:18 PM
10onpump7's Avatar
Default Re: Unable to locate M-Audio hardware??
help ??
Old 04-10-2009, 01:33 AM
smashbox smashbox is offline
There are many things that could be causing this. Try looking in the general troubleshooting at the top of the page.
Old 04-10-2009, 07:09 AM
divinetime divinetime is offline
i noticed a problem very similar, i went into my device manager and seen that my fast track wasnt set on the right drivers, i think it even came up as usb audio...
a way to determine if this is your problem... just open your volume mixer and make sure it says something like 1-2 or 1-2 fast track
if not just go into your device manager and set it to use the correct drivers.. the ones in the m-audio folder
'Unable to locate M-Audio hardware. Make sure your hardware is connected and turned o roland342 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-29-2012 09:01 AM
"Unable to locate M-Audio hardware. Make sure your hardware is connected and turned o MerryD Pro Tools SE and Essential (Win) 8 08-02-2012 12:59 AM
Unable to locate M-Audio Hardware. Make sure your hardware is connected and turned on ytass Pro Tools M-Powered (Win) 4 11-25-2009 12:49 PM
unable to locate m-audio hardware. make sure your hardware is..works fine in ableton? pein Pro Tools M-Powered (Win) 2 10-07-2009 12:01 AM
unable to locate M-Audio hardware. Make sure your hardware is connected and turned on joskraus Pro Tools M-Powered (Win) 13 05-13-2009 09:05 AM
