Old 10-12-2003, 07:56 PM
Darrell James Darrell James is offline
Default I can\'t setup my control panel
Im having a problem setting my digidesign control panel to my 001. The guy i bought it from did not have the 001 software but i was told the mbox le software would work and it does, but now im trying to listen to mixes through peak and jam and it won't come out the 001.when i try to set the digidesign control panel it gives me two options the first says mboxdissabled and the second one is the 001 #1 but when i select the 001 it dosent set it up.please help me.
Darrell
Old 10-12-2003, 08:09 PM
brinaddison brinaddison is offline
Default Re: I can\'t setup my control panel
I don't think the Mbox software will give you all the 001 options, I could be wrong but really you should just invest $75 and get PTLE 6.1 and install the Digi001 version.
This is the only surefire method.
www.hypeschwartz.com
Digi001
(RME adi-8 pro)
G4 MMD Dual 1g + 1.25g RAM
PTLE 6.4 (DVToolkit)
Mac. OS 10.3.3
3 Lacie 80g FW Audio Drives
Old 10-12-2003, 08:11 PM
dreamers dreamers is offline
I had a this problem when I tried to use my AM3 card with the Mbox software. I was unable to keep the AM3 card selected, it would reset to Mbox. I contacted the good people at Digi's Tech Support and they told me that there is a free "side grade" version of PTLE 5.1.1 download available for registard Mbox 5.1.2 software users. You might check it out in the software download section and see if you qualify. If not, then I believe you'll have to buy it. Contact tech support and ask them what your options are. Hope this helps.
Good luck.
Old 10-12-2003, 08:21 PM
The Pro Tools 5.x version for the MBox is not compatible with the 5.x version used with the 001 or 002. You need to buy the right version 5.x from Digidesign for the 001.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 10-13-2003, 09:26 AM
yep!
Digi001
(RME adi-8 pro)
Mac. OS 10.3.3
Old 10-15-2003, 01:18 PM
Thank's for the info. got the right software. Darrell
Control Panel won`t launch Niels T 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 12-14-2010 12:15 AM
MBox 2 Pro Control Panel ThunderKyss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-08-2009 10:17 AM
Delta 1010 setup - i/o panel? Sir Tode Pro Tools M-Powered (Win) 2 05-30-2006 10:26 PM
Help w/ Digi Control Panel gaston13 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-29-2004 12:42 PM
2930 setup and control panel settings utopian Storage Subsystems 1 04-24-1999 09:59 AM
