Go Back   Avid Pro Audio Community > General Discussion & Off Topic > Buy & Sell
Old 03-29-2016, 12:25 AM
Dirk Reinking's Avatar
Dirk Reinking Dirk Reinking is offline
Default FS Reel Tape Suite
Reel Tape Suite
Beef up your mixes and add that elusive magnetic vibe to your live sound
Avid brings the unmistakable warmth and punch of analog tape into the digital domain with Reel Tape Suite™. This powerful collection of three plug-ins — Reel Tape™ Saturation, Reel Tape™ Delay, and Reel Tape™ Flanger — is designed to beef up your mixes and add that elusive magnetic vibe to your live sound, without the hassle of actually owning and operating a reel-to-reel tape machine. Reel Tape Saturation models the inherent warmth of classic analog tape machines and tape formulations with astounding accuracy, instantly infusing your music with an authoritative "old-school" feel. Reel Tape Delay and Reel Tape Flanger duplicate electro-mechanical delay and flanging effects without cluttering your control room with large tape machines (or having to keep rewinding your echo tape), and give you real-time control over every nuance of these classic techniques.
• REEL TAPE SATURATION: Bring the warmth and punch of analog tape color and saturation into the digital domain
• Phase and frequency response characteristics modeled from three types of analog tape machines, Saturation effects modeled from two popular tape formulations
• Control the tape speed effect from 7.5 to 30 ips (inches per second), Noise controls adjust the amount of tape hiss
• Bias controls simulate the effect of under- or over-biasing the tape machine, Cal Adjust control simulates the effect of three common calibration levels
• REEL TAPE DELAY: Authentically modeled analog tape echo and delay effects
• Reproduce the fluctuations in tape speed, Adjust delays from 93 ms to 1,486 ms (1-7/8 ips to 30 ips)
• Feedback control adjusts the amount of delayed output fed back into the input, Wow & Flutter controls adjust tape speed fluctuation
• Bass and Treble controls in the echo/delay feedback loop allow for subtle to extreme feedback and saturation effects
• REEL TAPE FLANGER: Accurately reproduce analog tape machine flanging
• Adjustable speed control allows for manual flanging and artificial double-tracking effects, Feedback control adjusts the amount of flanged output fed back into the input
• Wow & Flutter controls adjust tape speed fluctuation, LFO Rate and Depth settings control the speed and depth of the flanging effect
REEL TAPE SATURATION CONTROLS AND RANGES Drive: –12 dB to +12 dB Output: –12 dB to +1 2dB Tape Machine: US (3M M79 emulation), Swiss (StuderA800), Lo-Fi (limited-bandwidth tape devices such as tape echo) Tape Formula: Classic (Ampex 456 emulation), Hi Output (Quantegy GP9) Speed: 7.5, 15, 30 ips Noise: Off (-INF) to 024 dB Bias: -6 dB to +6 dB Cal Adjust: +3 dB (equivalent to 250nW/m), +6dB (equivalent to 370nW/m), +9dB (equivalent to 520nW/m) PRESETS Bass Drum, Bass Gtr, Snare Drum REEL TAPE DELAY CONTROLS AND RANGES Speed: 17/8 ips (1486 ms delay) to approximately 30 ips (93 ms delay) BMP Sync: On/Off, Tempo/Rate, Triplet, Delay Time Feedback: 0 to 100 percent Wow/Flutter: 0 to 1 percent Wow Speed (Plug-in Automation Playlist or Control Surface Access Only): 0 to 100 percent Bass: –10dB to +10dB Treble: –10dB to +10dB Mix: 0 to 100 percent Noise (Plug-in Automation Playlist or Control Surface Access Only): Off (-INF) to -24dB PRESETS 3.75 ips, 3.75 ips Flutter, 7.5 ips, 7.5 ips Flutter, 30 ips Flutter, Rockabily, Rockabily Plus REEL TAPE FLANGER CONTROLS AND RANGES Range: -20 ms to +20 ms ADT: -20 ms to +20 ms Feedback: 0 to 100 percent Wow/Flutter: 0 to 1 percent LFO Rate: 0.05 Hz to 5 Hz Depth: 0 to 100 percent Mix: -100 to +100 percent Invert (Plug-in Automation Playlist or Control Surface Access Only) Noise (Plug-in Automation Playlist or Control Surface Access Only): Off (-INF) to -24 dB BMP Sync: On/Off, Tempo/Rate, Triplet, Delay Time PRESETS 12- String, Flutter Flange, Flutter, Manual Flange, Slow Flange, Vocal ADT, Vocal Walrus, Wobble
$150 please add iLok fee
cheers
d
Old 04-03-2016, 06:10 PM
tripstation tripstation is offline
Default Re: FS Reel Tape Suite
Might be interested
ProTools 12 HD
Pro Tools 10 HD3
Nuendo 11
Ableton 9
Avid Omni HD
Avid 8*8*8 HD X 2
D-Control ES 32 Channel
Native Instruments Maschine Studio
TC Electronic PowerCore *2
UAD-2
Universal Audio 1176 LN
Universal Audio 2-LA-2
Universal Audio 2-610
Neve DPX
Supermicro X10DAI Dual Xeon E5 v4 Win 10 64 128GB Ram
Old 04-03-2016, 10:02 PM
pmd
Old 05-13-2016, 09:13 AM
sold
Looking for reel tape suite protoolsuserman Buy & Sell 7 07-03-2014 10:51 AM
FS: Reel Tape Suite agershon Buy & Sell 2 06-05-2013 04:11 PM
WTB : Reel Tape Suite Dirk Reinking Buy & Sell 0 03-23-2013 03:44 AM
reel tape suite mdo9 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 10-24-2010 02:18 AM
Reel Tape Suite chardly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-16-2007 06:02 PM
