Old 04-19-2015, 01:55 AM
redloz redloz is offline
Default Import audio CD not working in Protools 12
I have this strange issue of not being able to import an audio CD into my Protools 12, the window gets stuck. The cd/dvd driver seems to work fine. This never happened with my previous Protools LE8.
Old 04-22-2015, 09:00 AM
Default Re: Import audio CD not working in Protools 12
It appears that my CD ROM SERVICE digi spti exe is not installed, not registered or damaged. I've re-installed Protools 12 without any luck. Finally I know what it is but I'm still unable to find a solution. Anybody...please???
Old 04-22-2015, 09:25 AM
Drew Mazurek's Avatar
Can you have the OS do it for you first?
I don't know anything about PCs or Windows, but on a Mac you can simply drag and drop from the Finder, then import to PT.
Makes sense?
www.drewmazurek.com
Old 04-22-2015, 09:58 AM
Hi Drew, on a mac it's very simple indeed. I installed PT12 on a powerbook and that works perfect. In my studio I have a big audio PC with a UAD card which I like to use for mixing. Just trying to get this setup working as well. I went totally legal with this PC, buying protools, an Mbox3 and never had any issues before. For example ableton 9 works like a dream, hassle free. Only use PT for postproduction with video. Need to import OMF and AAF files which is fine btw. It's probably a virus, this after a clean install :-(
Old 04-22-2015, 03:58 PM
The Weed's Avatar
The Weed The Weed is offline
One issue on Windows with drag-and-drop importing is "Running As Administrator". This is a recommended optimization, but, if done, won't allow drag-and-drop importing. Try turning that off.
Also QuickTime needs to be installed. Sometimes if QT is installed after Pro Tools, QT is not recognized. IIRC, there is a knowledgebase article about that.
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 04-23-2015, 02:53 AM
Thank you, Bruce.
I have Quicktime 7 installed before PT12. My way around this issue now is the following, using Itunes (Windows 7) this way I can import WAV files and later import them in PT12. Found another program: Pro Tools CD Ripping Service using SPTI Download & Updates by Avid Technology, Inc. but could not download it, false link. I thought by re-installing my AVID Pro Tools this would repair my so called damaged digi SPTI exe...apparently not.
Import Audio not working!! Spanglish Tips & Tricks 31 12-23-2015 02:59 PM
Import audio from Quicktime not working tdcmc General Discussion 0 09-09-2014 06:39 PM
Import Audio from QT .DV File Not Working Chief Technician Post - Surround - Video 17 04-30-2008 09:02 PM
Import Audio NOT working... Muzoid Pro Tools TDM Systems (Mac) 1 05-03-2007 03:39 PM
Import audio from workspace not working right MikeWeiss Pro Tools TDM Systems (Mac) 1 08-02-2006 02:16 PM
