Old 01-29-2015, 05:14 AM
KeyplayerG's Avatar
KeyplayerG KeyplayerG is offline
Default Is there any way to approximate a VCA setup on MC Control
Besides using layouts to sort of get a VCA control kind of set up, is there any way to get a true VCA operation using Artist Series components or is that just limited to the Sys5/Fusion/MC Pro level series?
Old 01-29-2015, 06:25 PM
KeyplayerG's Avatar
Default Re: Is there any way to approximate a VCA setup on MC Control
Any ideas? Anybody?
Old 01-30-2015, 03:30 AM
studiosus studiosus is offline
What is your question?
If you have pro tools hd, you can control vca faders from the artist series.
if you want to spill the vca members: no way.
Old 01-30-2015, 09:12 AM
scullionj scullionj is offline
I haven't used any of the boards you mentioned, but if they work similarly to Icon, are you referring to how you can do VCA spill?
Old 01-31-2015, 05:23 PM
KeyplayerG's Avatar
Yeah, I was talking about the spill. It can't be done on Artist Series units, right?
Old 02-01-2015, 10:36 AM
Yeah, you can't -quite- do it the way it works on the Icon, but you can either do the memory locations trick, or you can do it via groups & the group spill function on the touch screen. Doing that, you can manage show/hide status, basically, but it's not like the bigger boards where you can be showing something that's hidden in the edit/mix window.
Surround setup for Control 24 and PT klx5 Post - Surround - Video 0 04-08-2004 05:26 AM
Approximate time for PT6 and Magma Cardbus? doug_hti Pro Tools TDM Systems (Mac) 10 02-17-2003 10:17 PM
Approximate dimensions of the Digi 002? Phil O'Keefe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-19-2002 09:19 PM
Setup With Control 24 PuaFua General Discussion 0 10-26-2001 01:16 PM
What is the approximate performance gain from installing a second hard disc? MikeC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-03-2000 05:23 PM
