  #41
Old 12-22-2019, 12:26 AM
Emi's Avatar
Emi Emi is offline
Default Re: 2019.12 Discussion
Very stable here on Catalina. I Don’t do video work here so I don’t care about video support.
Mac Mini late 2012 i5 | Mac OS Catalina 10.15 | Motu 16A | Motu 828ES | Pro Tools 2020.5 Native
  #42
Old 12-22-2019, 12:33 AM
Southsidemusic's Avatar
Originally Posted by zion View Post
I don’t know why but 2019.12 seem to be more stable on 10.4.6 than 2019.10. It’s working really well here!
Same experience here. Feels much more stable and quicker overall. Maybe this last version of the decade is a winner
Best Regards
Christopher
South Side Music Group
WEBHOME
  #43
Old 12-22-2019, 12:40 AM
TNM TNM is offline
2019.10 has definitely improved performance at low buffers... the correct version of PT 2019 to be running on any PC imo. It's now only 10% behind Logic for VI track count playback at 128 buffer which ties it in second place for the mac performance DAW crown to reaper and way ahead of all others. Logic/Pt-Reaper/then............Cubase-Bitwig then.............................................. ........................everything else.
PT is great software and 2019.10 is awesome. Hopefully 2020 adds some nice midi features, pitch correct and folders. Here's hoping!
-iMac Pro 3.2ghz 8 Core, 64GB Ram, Vega 56, OS 10.14.6/Win10 Pro, TB3 Dock & 4xSSD, UA Apollo x3 + Octopre x3, Microlite x2, Midi Synths galore, PT 2020.3
-Aorus X5 V8, 6 core Intel 8850H, 32GB ram, GTX 1070, Win 10 Pro, PT 2020.3/Nuendo 10, Apollo Twin TBolt
-Whenever I launch Pro Tools, I get wet.(™)
  #44
Old 12-22-2019, 04:01 AM
Mike Thornton's Avatar
Mike Thornton Mike Thornton is offline
There seems to be some misunderstanding about macOS Catalina, Pro Tools 2019.12 and video workflows.
What Avid have done with Pro Tools 2019.12 running on Catalina is to enable MXF wrapped video files to run natively on Catalina with Pro Tools.
This means if you have existing or including projects all you need to do is to convert your QuickTime .mov videos to MXF. You can still use Avid DNxHD codecs, just make sure they are in an MXF wrapper.
There is even a free app Shutter Encoder that can do this. Check out my article With all the details including instructions and a demo video showing how to use Shutter Encoder.
Alternatives include using Non-Lethal Applications Video Slave 4, which would allow users to continue to use QT content with Pro Tools 2019.12 on Catalina.
Mike Thornton MIPS
Audio Meister and Editor of Pro Tools Expert
www.pro-tools-expert.com
  #45
Old 12-22-2019, 04:12 AM
Downtown_BE Downtown_BE is offline
same here! fingers crossed - maybe a version to stay for a while again
  #46
Old 12-22-2019, 08:44 AM
off the wall's Avatar
Originally Posted by jeam25 View Post
Indeed, it is stated that Apple killed 32 bit support with Catalina. The only way to run a 32bit with with a VM afaik. I can't imagine PT running 32bit process in Catalina, i think imo that the fact that PT 2019.12 is limited on import and video etc. is that they removed the 32bit process on it.
Just to be clear, the video limitations of 2019.12 apply only to installations on Catalina. I've been importing, exporting, bouncing to QuickTime .mov and .mp4, etc with 2019.12 under Mojave 10.14.6 with no issues.
Overall, 2019.12 Ultimate/HDX seems a bit more responsive and stable at extremely low playback buffers than the already good 2019.10.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, AMD 7970 GPU, SSD boot drive on 6Gb/sec PCIe card, 64GB RAM, MacOS 10.14.6.
Pro Tools Ultimate 2020.5. HDX, UA Octo PCIe cards, HD I/O, C|24 control surface.
Mostly Avid, Waves, Sonnex and UAD Plug-ins
  #47
Old 12-22-2019, 08:48 AM
DontLetMeDrown DontLetMeDrown is offline
Working good so far on my Win10 setup. Can't perceive any change whatsoever.
  #48
Old 12-22-2019, 09:37 AM
EGS's Avatar
EGS EGS is offline
Works!!!
Desktop: PT 2020.5 / Win 10 / GIGABYTE GA-X58A-UD3R / i7 hex 3.9GHz / 32GB / Focusrite LS56
Laptop: PT 2020.3 / Win 10 / HP ProBook / i7 quad / U-PHORIA UMC1820
Legacy: PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI001
Click for demo
  #49
Old 12-22-2019, 09:59 AM
SomeOtherGuy SomeOtherGuy is offline
Link please, thanks!
Found it:
https://www.pro-tools-expert.com/hom...tter%20encoder
Pro Tools Ultimate, Avid MTRX, MOM, Mac Pro 3.5 Ghz 6-Core (2014) 64 GB RAM, Mac OS Mojave, Samsung T5 SSDs
  #50
Old 12-22-2019, 01:30 PM
gives's Avatar
gives gives is offline
I totally agree with Southside music. I literally worked 9 hours on some scoring and mixing, adding a bunch of VI's and live parts. Everything seems very solid here to me. I was happy pretty much with the previous version, but this one is definitely more solid. I am not going to be running Catalina for a while until the video codecs are sorted out along with just having all of my plugins running for sure at 64 bit.
BTW, I am STILL seeing, although not as much, this issue when I playback a highlighted section in the timeline of an audio clip I get an error message that says that the video stopped or something.. A fix I found was to put Protools into a few seconds of Post Roll. Then it does not happen. It still seems to happen, but only happened after a few hours of working now.
Here is my original discussion link here: http://duc.avid.com/showthread.php?t=407076
Gregory Ives, Composer/Sound Designer/Musician
http://www.gregives.com
https://pro-labs.imdb.com/name/nm1170521/?ref_=sch_int
Protools 2019.12 Ultimate HD Native Thunderbolt Avid HD IO
Mac Pro 3.5GHz 6-Core Intel Xeon E5 64GB of Ram
OSX Mojave 10.14.6, Digital Performer 9.5, Logic Pro X 10.4.8
Pro Tools 2019.10 Discussion TOM@METRO Pro Tools 2019 94 12-05-2019 01:51 PM
Install pro tools 2019.10 over 2019.6? Clarkston Guy Pro Tools 2019 6 11-01-2019 08:12 AM
Updating from 2019 .5 to 2019.6? ihate100bees Pro Tools 2019 13 07-04-2019 08:30 AM
The -20 dB discussion Syncman Post - Surround - Video 10 11-12-2003 09:53 PM
