midi instrument track grayed out...???
for some reason some of my 'instrument' tracks are gray in the edit window. and midi info on them will not play back. if i put the track in record enable i get sound. or copy midi to a regular midi track and have it control the instrument track.
happened during a session. seemingly all of a sudden. did i hit something by accident? a keystroke to toggle between active and inactive? i did check the 'make active/inactive' button. track is supposedly active. ??? |
Re: midi instrument track grayed out...???
Sounds like the track has lost it routing to the instrument it was playing!! With "instrument view" on you will be able to re-connect its midi routing to the instrument its playing. Chris
That one gets me pretty often! I always forget the " Instrument View " option and I pull my hair out for a few min till I have the lightbulb moment. ha.
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8 PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626 •••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!• |
but it seems to be strange to me, that he can hear the (I assume correct sound) if he makes the track record-active
MP5,1 12core 3.46ghz 96GB Ultimate HDX https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ |
This is an incredibly annoying PT8 bug that happens to me almost every time I make an inactive instrument track active. What you need to do is pull up the inst view in the mix window, and then choose the appropriate midi channel to send your midi to, probably channel one. I've contacted tech support a couple times since 7.4 but PT 8 didn't fix it, it just added more annoying little bugs.
If the default thru instrument is set in user prefs, it could route to the default through instrument when selected or record-ready. Nothing unusual about this.
--Jeremy |
cool.
'instrument view' did it. thanks! wow, never used that before. up til recently i've only done live instruments. no midi... except for a click track or something... |
Pardon my ignorance, I'm new at this. Where do I find this "instrument view"?
Obviously, I'm having the same problem with the midi track being grayed out. |
in the lower left corner of the mixer-window you find a menu to configurate the mixer view. check 'instrument', then you´ll see in top of the instrument channel-strip a section for selecting the midi-channel
Thank you tonwurn! That did it, i can work now.
copy instrument track to midi track | trev1238 | Pro Tools 9 | 5 | 02-04-2012 01:16 AM |
Difference between Midi Track & Instrument Track better? | paul Neathery | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 07-16-2007 04:03 PM |
Mapping MIDI Track To Instrument Track | Delta Dreams | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-08-2007 11:26 AM |
midi outputs? aux track or instrument track? | pikapikapi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-19-2006 02:28 AM |
using instrument track vs. midi+auxilary track | digimike | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-02-2006 09:21 AM |
