Old 09-28-2007, 04:08 PM
Ozmo Ozmo is offline
Default Roland Edirol PCR-300 configuration with Mbox2
I just got my first real midi keyboard controller and I am confused as to how to connect and configure it in PTLE.
I am using the USB on the Edirol PCR-300 for power. There is also editor software for control map transfers through the PC.
Anyone else using one of these with the Mbox2?
Do I need to connect the midi cables to the Mbox2 also or do I just use the PCR-300's driver?
How should I configure the PCR-300 in Midi Studio and in the Peripherals setups?
Once I know that I have the connections and configuration correct, then I can worry about importing control maps for PT, Reason, and SampleTank.
Thanks,
Ozmo Lux'lucis
Taraxacum Officinale
Old 09-28-2007, 11:51 PM
johnnyboy5000 johnnyboy5000 is offline
Default Re: Roland Edirol PCR-300 configuration with Mbox2
You don't have to connect the keyboard to the Mbox2 via midi because the keyboard is connected through USB. I know on the mac, pro tools LE 7.3.1, go to Setup menu/MIDI/Input Devices and enable your keyboard. Put a check in the box to enable it.
Old 09-29-2007, 04:31 AM
accession accession is offline
Here's the Audio MIDI Setup I used back when I had a PCR-M30...
http://img.villagephotos.com/p/2005-...oMIDISetup.jpg
Not sure how similar it is to the PCR-300? I remember it being very confusing at first.
Hope that helps.
Old 10-01-2007, 03:20 PM
I have been able to get connected through USB. I am not using the MIDI cables at all. I couldn't get it set up as HUI under Peripherals though.
I am having success mapping controls through Reason Adapted and SampleTank2. Are there any CC mappings for Digi plug-ins?
Ozmo Lux'lucis
Old 10-02-2007, 07:17 AM
Only on instruments, such as Xpand, Hybrid, Structure, and the percussion mangler, Synchronic.
For everything else, it's HUI
Using a Edirol Roland PCR 300 with MBox 2. please help. stockyoafc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-22-2010 08:48 AM
Mactel & Roland/Edirol UM-4/SMPU-64??? Sonic Nomad 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-16-2007 11:40 PM
Roland Edirol PC-70 MIDI Controller - OSX & PT6? Kleekoh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-01-2003 04:50 PM
Roland Edirol PC-70 Controller - PT & OSX? Kleekoh MIDI 0 11-01-2003 04:47 PM
Roland Edirol cedricl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-04-2002 04:13 PM
