Old 05-11-2020, 06:39 AM
DJ Rae C's Avatar
DJ Rae C DJ Rae C is offline
Default Re: 192 + 96 + sync & Pro Control Monitor Routing
I finally got my system up and running, found a few anomalies in setup, harness but now all working as should, first thing is to use the 90i\o as you're primary i\o interface and not the 96ii\o or the 192 and I found by using the DB25-TRS reverse 1 & 2 to attach to monitor in on the P\Con to 7 & 8 and you will have sound\speaker monitoring working.
ITB signal routing photowriters Windows 25 10-27-2014 06:27 PM
Signal Routing Jel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-20-2009 07:32 PM
Signal Routing patrick_ny Pro Tools M-Powered (Win) 1 06-12-2006 07:41 AM
SIgnal ROuting basktqase 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 09-23-2005 07:34 AM
Internal talkback Routing for Procontrol newbie Shatner ProControl, Control|24, Command|8 2 03-15-2004 04:10 PM
