Old 07-08-2004, 07:10 AM
Jsalam112 Jsalam112 is offline
Default Control 24 firmware
My C24 is about 2 years old. I've never had any problems with it until now.
The serial# is: PW0171400F
Firmware: COMv1.08
I'm running:
Pro Tools 6.4 HD3 Accel
OS 10.3.4
G5 dual 1.8
Is this the correct firmware and if not where do I download the most recent version?
Thanks
Old 08-08-2004, 06:52 AM
Daniel Reis Daniel Reis is offline
Default Re: Control 24 firmware
i'm curious also. the firmware has to be updated at some point, there are lots of funtions writen on the control surface that does not work
Old 08-08-2004, 10:24 PM
hanz marathon hanz marathon is offline
unfortunately this is the 'latest' version. Digi could finally update.........
www.marathon-music.com
Old 08-16-2004, 01:17 PM
skullseven skullseven is offline
I cant find where to download the latest firmware version.
Old 08-24-2004, 04:37 PM
DigiTechSupt's Avatar
The latest version always gets installed with Pro Tools. If you change versions of Pro Tools it will change the version of it will Pro Tools will prompt you to download the firmware from your computer to your Control|24. Pro Tools should always install the appropriate version of firmware for your version of Pro Tools. If you are having problem with your Control|24 it is best to contact us directly. We can figure out what is going on and help you get it taken care of.
Thanks,
Digidesign Tech Support
Avid Audio Tech Support
Support FAQ
Old 05-18-2020, 11:15 AM
Teletoby Teletoby is offline
I have a similar problem, the faders are jumping around, but only after a time when the unit becomes warmer. It starts with bank one and after a time the bank two follows. I've tried already to clean all the connectors and else. I am not sure if its a software problem, but it doesn't seems like that, since it doesn't do right from the beginning.
Old 05-18-2020, 01:12 PM
things to consider:
1-since you dredged up a 16 year old thread for this, its likely better to start a new thread.
2-include a lot more information about the entire system
3-do you really mean a Control 24, or the newer C24?
4-based on your description, it would seem that a component is failing after heating up.
Old 05-21-2020, 05:46 AM
crizdee's Avatar
crizdee crizdee is offline
Classic sign of the power supply starting to fail. I used a Control 24 for 15 years and had this problem about 3 times with the faders not working correctly and its mostly the power supply. first bank 1-8 then bank 9-16 after its been on for a while. other thing to look at is the Molex connection from the power supply to the fader boards but as its happening on two banks i would say power supply.
Most common failure on the power supply is the C20 capasitor which can be removed and replaced quite easily if youre ok with a soldering iron.
Chris
Producer, Engineer,
www.ukmastering.com
Upgrade Firmware Pro control ? hart07 ProControl, Control|24, Command|8 4 08-28-2011 09:21 PM
Firmware issues on MC Control? chris_s_p Artist Series 2 02-21-2011 09:58 PM
Firmware on D-Control SWSPHX ICON & C|24 8 04-18-2010 04:35 PM
Firmware update on D Control SWSPHOENIX ICON & C|24 3 11-12-2009 11:51 AM
5.3.1 Pro Control firmware michael c ProControl, Control|24, Command|8 3 07-13-2002 04:33 PM
