Old 08-09-2010, 06:02 AM
Gazzieh Gazzieh is offline
Default Exporting MIDI not working
I have a Yamaha Tyros 2 and have recorded some music on the system directly (rather than into Protools via MIDI). I then use another program to transfer the created MIDI file from the Tyros onto my computer and import the MIDI into Protools - all works fine right now; 4 tracks appear that correspond to the 4 tracks recorded on the Tyros.
I then export the MIDI tracks back out as a new MIDI file. I do not include real-time properties and export as multitrack. I transfer the newly created MIDI file back on to the Tyros and then try to load it but it fails to load correctly (the only message I get).
I deliberately do nothing to the MIDI tracks I have imported into Protools so that the exported MIDI should be identical to the imported one but clearly it is not.
Anyone any ideas?
Old 08-09-2010, 07:37 AM
spkguitar's Avatar
Default Re: Exporting MIDI not working
Anyone any ideas?
I'm assuming you're export is just to test to see if this will work once you are actually editing the MIDI within Pro Tools? Otherwise, I don't see the point.
When you do the export from Pro Tools, which MIDI File Format are you selecting? 0 or 1?
There are some items in the Tyros manual's troubleshooting section about "write-protect", you should check that out.
What other program are you using to transfer the MIDI from the Tyros, specifically?
Old 08-10-2010, 10:16 AM
tritonkorg tritonkorg is offline
I've had a similar problem that I posted few days ago. The problem appeared after installing the latest version (8.04). I have a Digi002 running on Windows XP , Sp3. Please check out this thread:
http://duc.digidesign.com/showthread.php?t=279417
I make midi files constantly, and it's so annoying that I can no longer use pro tools to do that. In my case, everytime i hit export, the Task Manger window pops up, as if it's doing something in the background. It goes on forever. The midi file that's exported, is corrupted, and not recognized by any Software that I own. I've tried both 0 and 1 formats by the way.
Is anybody able to export midi with pro tools 8.04?
Old 08-10-2010, 11:18 AM
You're right spkguitar, I was doing this as a simple test of the system.
The file copies both ways without issue and I am using the Yamaha software for transferring midi files that comes with the Tyros.
I am using multi-track option (1) rather than single track (0) and I am now wondering if I have mis-understood what this meant. I am interpreting tracks as channels and maybe this is where my mistake lies?
Exporting Midi Sparky1 macOS 2 08-05-2013 10:50 PM
Exporting .MOV file not working? Dizzi45Z Post - Surround - Video 0 05-24-2011 09:47 PM
Exporting midi WernerF Pro Tools TDM Systems (Mac) 10 06-26-2010 03:54 PM
Importing and Exporting audio not working --WTF?? zboy2854 Pro Tools TDM Systems (Mac) 9 08-14-2007 05:03 AM
exporting midi mr. peregrine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-13-2002 05:10 PM
