Old 06-18-2002, 10:58 AM
pedrohead pedrohead is offline
Default mastering with STRICTLY 001 factory plugs
hey there,
i'm ready to start some mastering on a project i'm doing, and i'm curious which 001 factory plugs people have had success with. i know the waves bundles (C1, L1) are probably much superior, but i really can't afford them at this time, so please don't give me that recommendation. [img]images/icons/smile.gif[/img]
the main plugs i was considering are the Q10, La-2a/1176, maxim. are these the best 001 factory plugs for the job? is that the usual order (eq-comp-limiter)??
any help would be great, i'm really new at this.
and also, i did a search on all this beforehand, and there's no threads out there discussing the 001 factory bundle plugs much, just tracks/wavelab/L1-C1 lovefests, so save that recommendation, too. [img]images/icons/smile.gif[/img] help if you can. thanks so much.
Josh Wheeler
[email protected]
**Detroit Rock City**
Fitter, Happier Studios...
Old 06-18-2002, 11:13 AM
homerg homerg is offline
Default Re: mastering with STRICTLY 001 factory plugs
Pedrohead,
What I was doing before I got T-Racks is as follows: [img]images/icons/wink.gif[/img]
Bounce to disk as a stereo interleaved file at the same bit rate as the session was created in. Usually 24bit. Import the bounced track into either the same session or create a new one (in the same folder). If you import into the same session be sure to mute all other tracks.
Create a master fader, add EQ (if needed) but try to make most EQ adjustments before you bounce, a stereo compressor (don't over compress cause the Limiter does that too) just to smooth things a bit, now add the Limiter. The limiter will give the overall sound that even polished sound, but don't overdo it cause it could take some of life out of the song.
If you think you'd need to mess with stereo imaging and balance between left and right channels then when you first bounce to disk bounce as two mono tracks, that way you can play with the individual channels for the overall balance.
I got really good results this way.
Make sure to use the dithering while mastering, not while bouncing initially. I think you can set ProTools to use it as one of it's default settings but you can always add the dithering to the master fader, just make it the last plug-in you use.
ASUS A7N8X-E Deluxe
MD Athlon XP3200+2.20GHZ
Corsair XMS PC3200 400MHZ 1GB
WD EIDE 10GB
WD EIDE 250GB
XP Pro SP1
ProTools LE 6.4
Old 06-18-2002, 11:48 AM
thanks for the reply. those are good tips, i'll keep them in mind.
what i'm looking for more is ... what specific plugs did you use? were there any tricks or settings that made them more useful for this purpose?
Josh Wheeler
[email protected]
Old 06-18-2002, 11:54 AM
mattm mattm is offline
it is not possible to master with plug-ins. in fact, it is not possible to master a recording without years of valuable training and experience, as well as a darn good set of ears. please don't aid giving the valuable art of mastering as poor a name as the art of recording has come to earn due to the release of products such as "pro"tools into the wider community.
Old 06-18-2002, 01:12 PM
Don't listen to him Pedrohead. You go right ahead and master to your little hearts content.
Excuse me Mattm, but this is the 001 DUC, please go back to the TDM DUC where such comments might be appreciated.
The man wants to master and you're telling him it's impossible! Are you on crack! Get over yourself. [img]images/icons/mad.gif[/img]
Pedrohead, the plug-ins I mentioned don't come with any presets that are going to apply here, but what I did is played with each plug-in until I got the desired results, or close, and then I saved the settings so I could use them again. Of course, different styles of music will require different settings so you will need to keep saving settings that you like and you'll get better at it every time you do it.
Just like those mystic gurus that Mattm was talking about did before they learned to master.
I don't mean to get down on you Mattm but it seems to me that this is a place for getting incouragement, not to be shot down. [img]images/icons/wink.gif[/img]
ASUS A7N8X-E Deluxe
WD EIDE 10GB
WD EIDE 250GB
XP Pro SP1
ProTools LE 6.4
Old 06-18-2002, 04:37 PM
da BaSsTaRd! da BaSsTaRd! is offline
hold on now, homey - i think matt's on to something here. the truth is that you shouldn't be RECORDING with plugins or the digi 001 either for that matter. anything less than 64 tracks of analog tape and a 360 channel neve console isn't recording at all. without this equipment, you're guaranteed to get a sihtty sound so why bother trying?
in fact, without at least 15 years experience engineering under the wing of a true analog audio expert, you shouldn't try to record anything on your own. you may end up making a big mistake like having fun or writing a song or something foolish like that.
i love my apple iPhone!
Old 06-18-2002, 04:39 PM
pk_hat pk_hat is offline
<font size="2" face="Verdana, Arial">Maybe you could send him a check so he can get his music mastered by a professional?
Matt, although I see your point and advocate the fact that you can never achieve the same results at home as you would going through a mastering house, your reply was a little hairy.
We're all learning here, and slapping whatever plugins across a mix for a 'home made master' will only teach us about avoiding pitfalls and common mistakes. When we can afford mastering for a commercial release, then yes, we'll go to the man himself.
pk
www.myspace.com/krou
Old 06-18-2002, 04:45 PM
Stone Knife Stone Knife is offline
I have to warn you, the Digi Limiter is one of the most useless plugs in the lot.
It doesn't even work for speech correctly, (try it on a plain voice file.) ...so the idea of using it to master just is frightening.
YMMV, void where prohibited.
Har! daB writes
hold on now, homey - i think matt's on to something here. the truth is that you shouldn't be RECORDING with plugins or the digi 001 either for that matter. anything less than 64 tracks of analog tape and a 360 channel neve console isn't recording at all. without this equipment, you're guaranteed to get a *****ty sound so why bother trying?
<font size="2" face="Verdana, Arial">I didn't get the joke until after posting.
Old 06-18-2002, 04:57 PM
SKI's Avatar
SKI SKI is offline
<font size="2" face="Verdana, Arial">This statement can be perceived too different ways:
1)Don't waste your time [img]images/icons/mad.gif[/img]
or
2)You will need to learn how to use the products effectively. [img]images/icons/wink.gif[/img]
If it wasn't meant in a negative way then more clarification should have been given so that it would not appear that way.
I think it's important that we don't discourage other but instead help them to understand the importance of learning and understanding what you are trying to do.
URBAN MUSIC-
(Hip Hop and R&B)
Old 06-18-2002, 05:02 PM
Bloux Bloux is offline
[b]originally posted by Mattm
<font size="2" face="Verdana, Arial">Hey Mattm,
Take it easy there sportcoat, sounds like somebody missed his nappy nap today! Now you march back in there young man and tell Pedrohead your sorry for being so cranky! Go on!.. good boy, now here's your computer back! go nite nites!! [img]images/icons/blush.gif[/img]
Great Mastering plugs converted 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 04-10-2010 12:51 PM
///free mastering plugs onepercentfree 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 08-15-2009 06:06 PM
About mastering plugs Finnish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-30-2005 03:28 PM
Best mastering plugs? ajazzie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-26-2003 09:04 AM
RTAS Mastering plugs? discord3 Tips & Tricks 3 09-18-2000 08:33 PM
