HW Buffer Size = Video Latency as well?
Upon reviewing the manual..
HD: Getting started. Pg 30: "In addition to causing sower screen response and monitoring latency, higher hardware buffer settings can affect the accuracy of plug-in automation, mute data and timing for midi tracks" Does this also mean it can cause latency with video as well, say, outputting video through the firewire port? I am well aware of the video offset, but I'm wondering if that needs to be tweaked (again) if the HW Buffer size is altered. Do they "battle" one another? I suppose the same question could be raised with regards to the DAE buffer. Is there a recommended order in which to tweak each setting? Thanks!
.: michael kammes mpse .: post audio .: applications editor / workflow consultant .: michaelkammes.com .: lucidsound.com |
can't change the buffer size latency.. | ronnypro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-03-2010 07:56 PM |
Buffer size/latency problem... | Mikker21 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-09-2009 02:06 AM |
HW buffer size and latency | JPeters86 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-07-2007 11:22 AM |
Buffer Size and Latency issues | deryanagle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-15-2006 03:01 PM |
Recording Latency, Buffer Size, Plug Ins | JDL | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-11-2003 08:26 PM |
