Old 06-13-2006, 02:48 PM
skylab001 skylab001 is offline
Default clock problem relating to pitch of tracks
I just recorded a couple of great tracks at a friends house on his LE system, and when I opened the sessions on my system everything was faster and higher pitched. I finally figured out why after calling him and asking him about his settings. Apparently he recorded the session in 24 bit 48khz, but it was clocking to his preamp which was at 44.1khz. So I'm figuring when I open the session all the tracks are really 44.1 but are being played back at 48. I have tried opening the audio files in Peak and they say they are 48khz, but I think that may be because the PT session they were tracked in was tagging them 48khz, but really all audio was coming in at 44.1
So is there any way I can get this to play back properly. I can't think of anything that has worked yet.
Thanks
Brian
Old 06-13-2006, 04:04 PM
Chuck Fu Chuck Fu is offline
Default Re: clock problem relating to pitch of tracks
see this post:
http://messageboard.tapeop.com/viewt...413&highlight=
look at the Joel Hamilton post. I was able to fix a similar mistake this way. It was a little hard for me to wrap my brain around it, but it works.
Old 06-13-2006, 05:57 PM
Cool got it and fixed it up. Once again things are good!!
Problem detected with audio clock. Check your clock source and sample rate. sleeptalken Windows 5 02-26-2014 09:26 AM
Problem detected with audio clock. Check that your clock source and sample rate are c Solow1nonly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-06-2011 08:22 PM
problem detected with audio clock. check that your clock source and sample rate are c angeleda 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-05-2010 07:09 PM
word clock/sample rate pitch problem? NEED HELP! jgerards 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-03-2010 02:40 PM
"Problem detected with audio clock. Check that your clock source and sample......... ASD15 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 03-26-2010 03:40 PM
