Old 11-24-1999, 07:35 PM
agus agus is offline
Default waiting for delivery
I just purchased a 24 fader Pro Control.. still waiting for delivery. In the meantime, I'm curious about the customary wiring for the system. I've used PT for 6 years but always did the mixing on a console.
How is everyone wiring up the 888's? Is out 1/2 the main stereo out? What about 5.1 mixing? If I edit and mix at 24 bit, what happens when I want to go out to my 16 bit DAT machine?
Thanks for any input.
Allan
Old 11-24-1999, 09:57 PM
Coz Coz is offline
Default Re: waiting for delivery
I remembered reading this on the mac os troubleshooting under pro control monitoring problems. Hope this helps.
posted 11-03-99 03:28 PM
Hello,
As a result of some of the posts here regarding polarity when monitoring with the ProControl monitor section, we’ve performed tests on the AUDIO OUTPUT connector to determine if a problem exists. We have discovered a reverse polarity condition that affects the Control Room Out left/right, Slate/Dub Out left/right and Control Room ALT Out left/right connections. The (+) and (-) pin locations for these outputs on the AUDIO OUTPUT D-sub connector are reversed from what is shown in the ProControl User Guide.
Using a stereo monitoring setup as an example, if your monitor amp, powered monitors etc. inputs are wired as pin 2 hot (+) and pin 3 cold (-), the corresponding pinouts on the ProControl AUDIO OUTPUT connector (Control Room, Out left/right, for example) would be sending these signals as pin 3 hot and pin 2 cold. The simple "fix" for this is to reverse the pin 2/pin 3 locations at the XLR’s of your cable assembly. There are also commercial turn-arounds available for this purpose from companies like Switchcraft and Whirlwind. If your cable harness fans out to *" TRS phone plugs, reverse the tip and ring points.
We apologize if this has caused any inconvenience. To ensure all ProControl users know about this, we will be sending out a letter to all registered users in the near future.
Digidesign Product Management
Old 11-25-1999, 12:55 AM
Avid's Avatar
Avid Avid is offline
Administrator
See the Pro Control, Audio Output Addendum in the Documents section of Support at http://www.digidesign.com/serv/documents.html
Bruce Paine
eMarketing
Administrator
Terrible situation with weeks of waiting for delivery of HD Native in hardware exch. jacko General Discussion 4 12-07-2011 04:54 AM
Why is Digi waiting on 7.4? I have two clients waiting to... mozart Pro Tools TDM Systems (Mac) 18 11-08-2007 04:33 AM
M & E Delivery SurroundNewbie Post - Surround - Video 1 04-17-2004 03:16 PM
What is the best db for delivery? RobMacki Post - Surround - Video 10 07-24-2002 03:36 AM
Dual G4.. waiting and waiting for PTLE to load DChung 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-16-2000 08:39 PM
