Old 04-19-2018, 10:03 PM
mikeyman's Avatar
mikeyman mikeyman is offline
Default Mix buss stereo wide plugin
is there a plugin that comes with PT's10 that I can use on the mix buss to widen the sound image
Old 04-20-2018, 03:02 AM
Sardi Sardi is offline
Default Re: Mix buss stereo wide plugin
There is a stereo widener plugin made by AIR that is part of the standard PT package.
As someone who works in mastering, I strongly advise you not to go down this path. You’ll do more harm than good.
If you feel your mix isn’t wide enough, go back to the mix down and make it wider. There’s dozens of ways you could try to achieve this. Trying to do it on the 2 buss is the wrong approach.
Old 04-20-2018, 06:49 AM
dtmprod dtmprod is offline
I would concur. And just do that on a couple tracks/stems. Trying to make everything sound 'wide' just ends up creating the illusion that nothing's wide any more
Old 04-20-2018, 07:12 AM
Stig Eliassen's Avatar
Width = a difference between left and right channel. The concept is easy, but can be harder to achieve sometimes.
Old 04-20-2018, 01:07 PM
mikeyman's Avatar
ok thanks guys
Old 04-20-2018, 02:10 PM
As above, but a little more advice; use a widener on a few things. Example: Send hat, ride and overheads to a stereo AUX track and insert a widener on the AUX(I like Waves Vitamin for this as you can choose to only widen higher frequencies). Or try a widener on a reverb(with the reverb on its own AUX track, insert a widener after the reverb plugin). Remember that wideners work by messing with phasing(which is why its not good to do on a whole mix)
Old 04-20-2018, 06:52 PM
mikeyman's Avatar
yes thanks good advice guys
Wide Stereo Tracks to M/S ? for mono Compat mixes? SuperReverb Pro Tools TDM Systems (Mac) 1 11-15-2010 04:11 PM
wide stereo distorted guitar tips...give 'em up Allen Tucker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 07-30-2005 06:39 PM
How to wide a stereo image Riccardo Corbari Tips & Tricks 22 02-17-2005 12:17 AM
What's your favorite stereo buss compressor plugin Imagine Pro Tools TDM Systems (Mac) 31 02-11-2005 03:02 PM
Wide stereo image. Ben Jenssen Tips & Tricks 20 08-12-2002 02:56 AM
