Old 08-10-2017, 02:47 PM
Xcurve Xcurve is offline
Default Ram Upgrade- PT12 dead in water.
Hi All,
My system was running fine with PT 12.5.2 and OS 10.12.6 until I tried to upgrade the RAM from 16GB to 32GB. Mac wasn't seeing two of the RAM slots so I needed to clean and reseat card until I saw the 32 GB say ok. Now PT 12 is not usable. PT boots but takes about 10 minutes to open a small session with zero plugs. Pressing play gives me a video engine error.
I went back to the old 16GB of RAM and trashed the PT prefs. Zapped pRAM. Still no good. Same problems. What's next? Reinstall 12.5.2? Please help. Thanks!
Mac Pro 5,1
RAM- 16GB
Avid MBox Pro2
Old 08-10-2017, 03:17 PM
Default Re: Ram Upgrade- PT12 dead in water.
FYI,
Mac Pro (Mid 2010)
2.8 GHz Quad-Core Intel Xeon
16 GB 1066 MHz DDR3
Old 08-10-2017, 03:39 PM
john1192 john1192 is offline
Originally Posted by Xcurve View Post
FYI,
Mac Pro (Mid 2010)
16 GB 1066 MHz DDR3
sometimes if the RAM is not ALL the same Model it will give you issues .. sorry to hear you are having issues ..
have you gone to your Recovery Disk and Repaired your disk in first aid ... remembering that we do not have the Repair Permissions option in Sierra anymore ..
there is not much to do ... pRam as you tried - how many Chimes did you do ??
.. you can also try apple opton O & F .. used to help but not sure if it will anymore ..
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 08-10-2017, 04:27 PM
Thanks for responding. It's OWC RAM. Matched sets both 16 GB and 32 GB. pRAM two chimes. I do have a bootable clone drive that I made with CCC that I thought had 10.9 on it as I went from 10.9 to 10.12. I booted with this drive. PT works fine but in About This Mac it still says 10.12.6 (?).
Old 08-10-2017, 06:42 PM
Mixchump Mixchump is offline
Also, be aware that if you're upgrading the RAM in a 5,1 even though the RAM might be 1333MHz, if you fill all 8 slots, it will slow down to 1066MHz.
I'm pretty sure it runs in triple channel mode, so you're best to do 3 sticks on each side and leave two slots empty.
Old 08-10-2017, 07:41 PM
My Quad Core only has four slots for RAM which I thought was the norm. I still went back to the old 4x4s after things went south.
Old 08-11-2017, 08:27 AM
i only have 3 slots Filled in my 6 core .. 24gb (3x8gb) .. i read the same thing about filling all the slots .. might be a worth the try to only fill 3 slots (or 6 if dual processor)
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Dead in the Water due to iLok issues off the wall macOS 8 02-25-2014 09:41 PM
Dead in the water with 11.0.2 philgrab Pro Tools 11 3 12-10-2013 09:12 PM
Dead in the water midnightsun Pro Tools TDM Systems (Mac) 4 07-01-2008 07:17 AM
Dead in the water David Gans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-23-2007 11:44 AM
What happened!! Digi 002 dead in the water sricabla 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-03-2006 10:06 PM
