  #71
Old 12-16-2016, 11:39 PM
Justiceb707 Justiceb707 is offline
Default Re: Can't import audio (Assertion Error Line 559) with Pro Tools 11 on El Capitan
I had the same issue. I just recently updated my back book to sierra now I'm not able to change my I/O in Pro Tools 11.1.1 can anyone assist me?
  #72
Old 12-17-2016, 05:32 AM
musicman691 musicman691 is online now
Did you not check the compatibility page BEFORE you went to Sierra? PT11 is not now, and never will be, compatible with Sierra. You have two options - either backdate to an OSX version that will work with your PT11 version or go to PT12.
Jack
QAPLA!
  #73
Old 01-17-2017, 05:03 PM
mike081377 mike081377 is offline
Can someone tell me what to do if pro tools cd doesn't recognize on my iMac
  #74
Old 07-11-2017, 12:20 PM
aidanavey aidanavey is offline
Default Can't import audio into Pro Tools 11?
Hi guys,
Relatively fresh to Pro Tools (used it a bit during my Music Tech degree, but mainly kept to Logic) and i'm trying to move over and gather skills in multiple DAWs. However, whenever i'm in a project and I go to import audio (using the command, shift & I shortcut) it simply won't load audio into the main project window. It comes up with this error message:
"Could not complete the Import Audio command because Assertion in "/Volumes/Development/151228/ProTools/NewFileLibs/Cfd/MacBuild/../MacOS/Cfd_ImportAudioDialogMacOS.mm", line 559."
Any ideas on what this problem could be? Running PT11.3.1 if that is any help
Thanks,
Aidan.
  #75
Old 07-27-2017, 10:21 AM
Ayotteted Ayotteted is offline
Default Cant import audio (Error Message)
Could not complete the Import Audio command because Assertion in "/Volumes/Development/148093/ProTools/NewFileLibs/Cfd/MacBuild/../MacOS/Cfd_ImportAudioDialogMacOS.mm", line 559.
I just downloaded Protools 11 ...And installed it ...And I get this message when trying too import audio .... Also non of my plugins load ...I can see them but nothing happens when I try and put them on a track.
I also notice on the mixer screen non of the faders move when I click on them.... I have downloaded the PT Prefs app and zapped everything but it is still the same ....Any help Please
Macbook Pro 15"
Sierra 10.12.5
Focusrite
2 GHz Intel i7
16gig Ram
Protools 11 Version 11.3.0
BiographyEdit Value
Last edited by DigiTechSupt; 07-27-2017 at 10:33 AM. Reason: Merged with existing thread.
  #76
Old 07-27-2017, 10:37 AM
DigiTechSupt's Avatar
Post Re: Cant import audio (Error Message)
Macbook Pro 15"
Sierra 10.12.5
Focusrite
2 GHz Intel i7
16gig Ram
BiographyEdit Value
Hello Ayotteted,
Pro Tools 11 was not qualified beyond Mac OS X 10.10.5, and this is a known limitation on newer operating systems. Please see http://avid.force.com/pkb/articles/C...tibility-Chart
An upgrade from Pro Tools 11 is available at https://shop.avid.com/ccrz__ProductD...?sku=DYNA20008
Best regards,
JC
Avid Audio Tech Support
Support FAQ
  #77
Old 07-27-2017, 11:48 AM
Default Re: Importing Audio issues
Originally Posted by Bill Pool View Post
You may need to upgrade Pro Tools to version 12. Pro Tools 11 isn't compatible with El Capitan.
So I will have to upgrade to 12 ? ...What was the point of letting people download a demo version that will not work with my Operating system on my Mac ....And no option to demo 12 ...... Useless waste of time
  #78
Old 07-30-2017, 10:53 AM
alberta.oliver alberta.oliver is offline
Default Re: Can't import audio into Pro Tools 11?
To my knowledge protools doesnt import on this version of you have to grab whatever it is that you want to work on and drop it directly into your session (drag and drop) Hope this helps.
  #79
Old 07-31-2017, 03:47 AM
How is a web page supposed to know what operating system you're going to run PT on? You could have multiple Macs running different OSX versions - how's Avid to know which you're going to use? Take me for instance - the Mac I do internet & Photoshop on runs Snow Leopard and my daw iMac runs Mavericks. How would Avid know which machine is going to have PT installed on it?
You have no one to blame but yourself; should have checked the compatibility charts first.
Jack
QAPLA!
  #80
Old 07-31-2017, 04:19 AM
Originally Posted by aidanavey View Post
Hi guys,
Thanks,
Aidan.
What version of OSX are you using? If Sierra then things wont' work. You'll either have to move to PT12 or downgrade your OSX version if possible.
Dangerous and wrong info. There isn't a PT version that won't import audio providing one is running a compatible operating system
Jack
QAPLA!
Any ideas how to fix this error during audio import: Assertion... line 603. luism Pro Tools 12 3 03-14-2018 11:36 PM
Pro tools 9 assertion error cannot import any data blazinbk Windows 4 04-30-2012 06:52 PM
Can't Import Audio from QuickTime Video -- Assertion Error David Ziegler Pro Tools 9 28 09-18-2011 04:09 AM
Error: "pro tools could not complete the import audio command because assertion in" elsterNJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-15-2009 09:38 AM
