Old 01-14-2011, 10:43 AM
Syn-g Syn-g is offline
Default MC Mix in Hui Mode on PT9
IS anyone successfully running a MC Mix in Hui Mode in PT9. I want to be able to use my C|24 alongside MC mix. I've been told that you can't run Eucon and C|24 Ethernet at the same time.... Anyone doing this or can test?
PTHD6 / C|24 Controller / Euphonix MC Mix Controller / PT v.10.2
Intel MacPro 2.8ghz Quad Xeon / 18gigs ram/ PE6R4 Expansion Chassis w/Core,4 accel,1 process card, 46" & 24" monitors
Syn-g
www.bulletsage.com
Old 01-14-2011, 10:28 PM
GW GW is offline
Default Re: MC Mix in Hui Mode on PT9
Was just asking myself the same question. What you CAN DO however, is to run Digi 002 via FW together with the MC Artist Line running EuCon and that is a supersmart solution since you then bank the Digi 002 separetly from the MC Mix so you can either have them on the same 8 tracks OR bank the MC Mix and let the 002 stay put. It actually works better that way, then the MC Mix works together with the MC Control! Strange!
PT 12.4.0, iMac 27" Retina 4GHz i7, 32GB RAM, PoCo x8,
Digi002 Fact., Logic X|FCPX|Motion
Plugins: Waves Diam. V9|Artist Sign Ser.|SSL|GTR3.5, TC MD3|Harm4|VSS3|DVR2|Nonlin|Unwrap, Sonnox Infl|Dyn, Autotune
VI: Reason 8, Ivory It., Trilian|Omnisphere, VG2/RealGuitar, Kontakt6|GPO, Goliath|Gypsy|Fab Four, Candy, Structure, EZdrum, BIAB Audiophile
Hardware: TLM49|TLM103, SPL Track One, TC M-One, Artist Contr.v2|Transp|3xMix
Input mode and virtual sound check mode gagaiop VENUE Live Sound Systems 1 07-15-2010 11:37 PM
Grid mode, shuffle mode, spot mode and slip mode. RogTaylor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-24-2010 10:30 AM
mono mode vs multi input mode in Audio Suite plugin? thenewnoise Pro Tools TDM Systems (Mac) 4 09-30-2009 06:58 PM
Can't Change Automation Mode while in Play Mode menotyou ProControl, Control|24, Command|8 6 09-16-2004 06:29 AM
Windows Classic Mode or XP Mode? Bermaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-16-2004 01:58 PM
