Old 12-30-2010, 02:40 PM
Gemylon's Avatar
Gemylon Gemylon is offline
Default Re: Can't get 2.5.6. to work :-(
Originally Posted by Ryan Young View Post
I have the same issue. If I close EuControl and re-open it, it seemed to work.
This have no effect on the issue over here...
G
Old 12-30-2010, 03:02 PM
Gemylon's Avatar
Just thought I'd mention,
that I have updated all Firmware on my MCControl/Mix.
Thanks
G
Old 12-30-2010, 03:26 PM
The golfer The golfer is offline
Exclamation Re: Can't get 2.5.6. to work :-(
Gemylon,
I have a MC pro and not a MC so I am not sure if my solution can apply to you but it might worth a try.
I also own a mac pro with two ethernet ports. I use Ethernet 1 for the mc-pro(system 5 mc) and Ethernet 2 for internet. I know it might sound obvious but the first thing to check is your network preferences to check if your mac has a valid IP. Sometime when using DHCP you have to renew "the dhcp lease" to get a proper IP address.
Also, with the MC pro there is a MC euphonix preference in the system preferences. Open it and make sure the proper ethernet port is selected in "network interface"(ethernet 1 in my case).
In the past I remember solving an issue where my network was showing a proper IP address for my mac but my MC pro was not seeing my computer. I solved the problem by hitting "stop" in the bottom part of the MC euphonix preferences(in the system preferences)to terminate and disable auto-launch of Eucon app and then I reactivated it again.
I hope this can help!
Serge Hamel
Mixer / Sound Designer
http://www.netpostproduction.com
Old 12-30-2010, 04:15 PM
Gemylon's Avatar
Hi Serge
Thanks for taking time to help.
But I have gone through all this steps with the Network already.
No solution so far.
This whole issue actually looks kind of weird to me.
I think I have tried all there is to try.
Anyway,
I have sent a report to Digi Support,
and waiting for them to get back to me.
I'll see if they have any new tricks to offer...
Thanks
G
Old 12-31-2010, 10:38 AM
Gemylon's Avatar
OK ... It's working now...
In order to make it work,
I had to delete one of my existing User accounts,
and only use one.
Looks like EuControl had problems with two accounts... ?
Anyway, after I did this, I had no problems.
Thanks
G
  #16
Old 01-01-2011, 04:18 PM
It's good to know. I am glad you got it working.
Happy new year!
Serge Hamel
  #17
Old 01-02-2011, 01:03 PM
Gemylon's Avatar
Hi Serge
Happy New Year !
G
  #18
Old 01-05-2011, 05:23 PM
RuffinMedia RuffinMedia is offline
Originally Posted by marty martin View Post
That's got it for me too!
Deleting the preferences.
Why didn't I think of that?!!!
Can someone tell me which folders contain the Prefs for PT9 and Euphonix. I'm having a strange issue and I want to try deleting the Prefs for hopefully my issue.
  #19
Old 01-05-2011, 05:25 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
I'm finding that I have to keep closing EuControl and reopening it (4 or 5 times). Eventually it connects and everything works fine. I've tried trashing prefs but it still continues to act the same. Might just have to wait for an update (a relatively soon one I hope)
-Ryan Young
•Pro Tools 12.6 (x2)
•OSX 10.11 & 10.12
•Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon (x2)
•16 GB 1333 MHz DDR3 (x2)
•HD Native PCIe (x2)
•HD Omni (x2)
•192 i/o
•96 i/o
•4 Seagate Barracuda 1.5TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
•Blackmagic Intensity Pro (HDMI)
  #20
Old 01-06-2011, 12:25 AM
GW GW is offline
User configurations. Where to look -
Macintosh HD/Library/Application Support/Euphonix/UserSets/MC2User/MC_USER_SET__Root/
(safe-copy these before going on - you can put your downloaded ones here as well)
You find your prefs here (if you need to trash them or back them up) -
House(+name)/Library/Preferences/ called: com.euphonix.eucon.plist and com.Euphonix.EuControl.plist
House(+name)/Library/Preferences/Euphonix/ called: EuControl.cfg
Macintosh HD/Library/PreferencePanes/ called: Euphonix.prefPane
PT 12.4.0, iMac 27" Retina 4GHz i7, 32GB RAM, PoCo x8,
Digi002 Fact., Logic X|FCPX|Motion
Plugins: Waves Diam. V9|Artist Sign Ser.|SSL|GTR3.5, TC MD3|Harm4|VSS3|DVR2|Nonlin|Unwrap, Sonnox Infl|Dyn, Autotune
VI: Reason 8, Ivory It., Trilian|Omnisphere, VG2/RealGuitar, Kontakt6|GPO, Goliath|Gypsy|Fab Four, Candy, Structure, EZdrum, BIAB Audiophile
Hardware: TLM49|TLM103, SPL Track One, TC M-One, Artist Contr.v2|Transp|3xMix
Audio Suite plugins that work in 10, do they work in 11? David Sandwisch Windows 1 08-10-2013 08:14 PM
The plugs that WORK and DON'T WORK on 7.0 The Mink 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 02-10-2006 10:12 PM
New Mic won't work DougSt.Louis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-12-2002 09:06 AM
How does Direct Connect work?? (Does it work well??) tommydee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-18-2001 08:13 AM
