Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 10-28-2008, 07:28 AM
joeydego's Avatar
joeydego joeydego is offline
Default digidesigns AS plugins
do the digidesign or bomb factory audiosuite plugins introduce latency?
Old 10-28-2008, 08:52 AM
mradlauer1 mradlauer1 is offline
Default Re: digidesigns AS plugins
RTAS plugs should not introduce latency... Audiosuite plugs process off line, so there would be no latency with those at all.
White Macbook OSX 10.5.5 2.2Ghz Core 2 duo 4Gb RAM
PTMP 7.4.2
M-Audio Profire 2626 and Focusrite 26 I/O via lightpipe.
Focusrite Platinum Voicemaster Pro
KRK RP8's
1Tb Dual drive array.
Old 11-01-2008, 11:30 PM
LesPaul666 LesPaul666 is offline
Some RTAS plug-ins will introduce latency. Audiosuite plugs don't introduce any latency.
Old 11-08-2008, 10:22 AM
joeydego's Avatar
thanks fellas, can digisupport confirm this?
Old 11-11-2008, 11:32 PM
Stiff Stiff is offline
I can confirm it for you - there are several RTAS plug-ins that introduce latency. Like mradlauer1 said, AudioSuite doesn't because it's a rendered process. The latency with Audiosuite is the processing.
You can check the latency of RTAS plug-ins by cmnd-clicking the volume scribble on the channelstrip that holds the plug-in.
Daily news & reviews
www.ProToolerBlog.com
Digidesigns Hardware issues,post them here... gdx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-06-2008 11:40 AM
digidesigns hardware is in use problem! jakeelee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 11-26-2004 12:01 AM
Digidesigns support for Windows Holadrio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 05-17-2004 12:15 AM
My IRQ says I have 2 Digidesigns in 10 and 11. TriAxis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-09-2001 11:19 AM
What are Digidesigns plans for Surround Plug-Ins? Ah D O General Discussion 1 04-15-1999 01:39 PM
