Old 11-27-2007, 12:05 PM
songman0412 songman0412 is offline
Default DIGI 002 channels 1 thru 4 out
Hello,
I am running ptle 7.4 on windows. My Digi002 was working fine previously, but now mic and line channels 1-4 are not working. My software settings are fine. When I plug into channels 5 + with an outboard mic pre, everything is fine. Has anyone encountered this, or is there anything obvious I may be missing?
I chacked both mic and line settings, with and without phantom power for the pre.
Thanks
Old 11-27-2007, 12:19 PM
spkguitar's Avatar
Default Re: DIGI 002 channels 1 thru 4 out
Nope.
It's hard to say without more information from you.
  • What, exactly, are you trying to connect?
  • Where/how are you connecting it?
  • You said "My software settings are fine". OK, then what are they?
  • what exactly "isn't working"?
Old 11-27-2007, 12:32 PM
I am connecting a condenser mic to channel 1 mic pre, phantom power activated. The front panel switch is depressed for "mic", and the gain is turned up to about 3/4.
I created a new mono audio track. It is record enabled, and auto input monitoring is on. My i/o setting is default for digi002 for both input and output.
I'm getting no signal. When I switch to line input channel 1, front panel switch set to line, using an outboard preamp with phantom power, I also get no signal.
I repeated the above on ch 1-4 and get the same results.
When I use the outboard pre into line channels 5+, I get signal. The adat channels also work using an outboard lightpipe pre.
It seems strange that all four channels would go out, and I'm certainly not above missing something simple.
Thanks for any insight.
Old 11-27-2007, 07:22 PM
Is there possibly a simple setting I have overlooked, or is this a hardware service issue?
Thanks
Old 11-28-2007, 07:30 PM
spkguitar's Avatar
On your I/O dialog, are inputs 1-4 checked or unchecked? That's the only software setting I could think it would be.
Otherwise, you might want to get the unit serviced.
Old 11-29-2007, 08:03 PM
Have you had the unit open recently for a power harness repair? Maybe you didn't get everything all plugged back in or you jarred a connector loose on the audio board.
Channels 3 and 4 on my Digi 002 are flickering Trevorj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 04-11-2013 09:44 AM
8 More Channels on my Digi 003 Major Matt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 04-22-2010 04:59 AM
Please Help....more channels digi 001 jwagner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-27-2003 09:04 AM
digi 001 16 channels out mada 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-21-2000 10:28 PM
16 & more ADAT channels with Digi 001 Manfred Kohlbauer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-27-2000 06:00 PM
