Old 05-19-2017, 06:26 AM
dtmprod dtmprod is offline
Default Re: PT's dual low latency buffer, 110 instances of Kontakt 'n stuff.
Originally Posted by Sardi View Post
IIRC correctly, there's 2 stages of buffer lengths dependent on what you set it too.
So for example, if you set it to 64 it has a playback buffer of 1024. If you set it to 512 it has a playback buffer of 2048.
I'm making those numbers up, but I recall reading something along those lines when 11 was launched.
If that's true, wouldn't it show up in the delay compensation for individual tracks? Higher numbers for a higher buffer? Or would it only be noticeable in total system delay?
Old 05-19-2017, 06:33 AM
clausiii's Avatar
clausiii clausiii is offline
No, this has nothing to do with delay compensation.
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2019.5
Digidesign Command|8
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 05-19-2017, 07:57 AM
Originally Posted by Marsdy View Post
The video is here: https://youtu.be/6JzwngQbgHE - The info is 2'19" in.
Dave
This AVID video must be BS? Or, I am doing something terribly wrong and/or misunderstanding that'a going on here....? -
I'm midway through a mix. As an experiment I've deliberately frozen all instruments and committed all Elastic, so only audio tracks are running. I've disabled Melodyne. There are no tracks in input monitor/record ready.
So, if I understand correctly, I should be able to set the H/W buffer to 32 samples and it not affect playback at all......? .... Have I missed something? - -
https://vid.me/OJnP
TOM@METRO's Avatar
The way I understand this, the playback buffer on all audio tracks in playback is internally set at the maximum buffer for the sample rate you are using. Tracks in Record are set by the user in the Playback Engine drop-down menu. For Instrument Tracks, both Playback and Record are set by the user.
When a VI track is Committed, it is treated like an Audio Track.
I hope this helps.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2019.6 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 05-19-2017, 08:01 AM
I hope this helps.
So why I can't I run my mix with a H/W buffer of 32 samples then, if this setting is not affecting playback?
Old 05-19-2017, 08:08 AM
You are missing the other part of the equation. The buffer size also dictates how Pro Tools is prioritizing your CPU distribution. At a low buffer, the CPU is being prioritized for latency, as the buffer gets higher, its being prioritized for power.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 3-6-18)
Intel I7 6800k
Win 10
Old 05-19-2017, 08:10 AM
TOM@METRO's Avatar
I wish I had a complete answer. My tests show what I have referenced above, but there may well be background activity about which we have little information. I fully agree that lower buffer settings do show an increased CPU load, and that does throw questions that have (so far) not been answered in detail.
Are there any Instrument Tracks in the session you posted?
And then, there's Steve's new post above mine.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Old 05-19-2017, 08:12 AM
Are there ant Instrument Tracks in the session you posted?
There were frozen instrument tracks, but I tried committing them to straight audio tracks and it still did the same thing.
Old 05-19-2017, 08:16 AM
TOM@METRO's Avatar
Then perhaps there is much more going on here than the simple Avid explanation implies.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Old 05-19-2017, 08:17 AM
BUT the AVID vid claims that you can set a low buffer without affecting other playback tracks at all....? "This allows the user to get the lowest possible latency without having to constantly adjust the buffer or the session"
How many instances of Kontakt can you run in the new pro tools HD 11? Meccanizm Pro Tools 11 5 04-10-2013 11:42 AM
Anyone using Kontakt 3 or NI Stuff With PT8 And Getting By? epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 12-17-2009 01:53 PM
This buffer stuff is making me mad. meltdown5 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 07-25-2006 10:45 PM
Buffer Issues and other stuff sainsomnia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-19-2006 12:44 PM
New section for Dual monitor stuff Ray Fabi Pro Tools TDM Systems (Mac) 1 04-18-2001 10:41 AM
