Operating System held off interupts for to long
Does anyone have an idea as to why I keep getting this error 6096(Operating System held off interupts for to long, if this continues increase the hardware buffer size in the playback engine). I have increased and decreased the buffer size and I still get the error. I have Protools installed on a second physical drive that is 7200rpm, but my operating system drive is 5400rpm and I notice that the plug-ins and other folders related to Protools is install on the System drive that is 5400rpm. The application itself (Protools) is installed on the second drive 7200rpm. Do you know how to install the plug-ins to a different directory? I am a new protools user. Please someone help!
Re: Operating System held off interupts for to long
You should leave Pro Tools installed on your system drive, but that's not causing your problem.
You should list the details (CPU, memory) of your system, and what Digidesign hardware you're using.
Quad 2.5 G5, 4.5G RAM |
It's more important to know where you are creating your music files. Are you creating them on the 5400 RPM system drive... that's a problem.
But list your system details...
www.carvelstudios.com |
I have a Hp athlon Xp 2800 with 512mb pc3200 ram, and 5400 rpm maxtor system drive and my second drive is 7200 rpm maxtor.
I record audio files to the 7200 rpm second drive.
Which Digidesign hardware are you using?
You should install Pro Tools to your boot drive (not imperative, but highly recommended). Do you have DMA mode enabled for your hard drives? How many plug-ins are you talking about when this happens? Rail
Sorry about that. I'm using the digi002ru and dma is enabled. Is it okay to install Protools
to the system drive if the drive is only 5400rpm, or should I remove the 5400rpm drive and just use the 7200rpm drive partitioned into two drives and re-install WinXP with protools installed on the root. |
It doesn't matter if the system drive is slower.. as long as you're not recording audio to it. When you create your sessions.. always create them on your 7200 rpm drive.
Which FireWire card do you have? Rail
I first received the message when i was running about 8 plugins mostly d-verbs and compressors.
Now I receive the error when I record the first track of the session with 44.1 sample rate and 24bit and 16bit plaback using one plugin. |
I'm not sure which firewire card I'm using, it's the one that came with my system HP Pavilion Athlon XP AMD2800, 512ram. I'm not
in front of my PC at this time because I don't have Internet access at home. I will try to install protools to the system drive and record to the second drive that is 7200 rpm. If you have any other suggestions please let me know and thank you for helping. |
"THE OPERATING SYSTEM HELD OFF INTERUPTS FOR TOO LONG | Don Anger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 39 | 04-26-2007 05:43 PM |
Operating system held off interupts too long... | thirdvalve | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-18-2007 02:39 PM |
the operating system held off interupts for too long | djacts | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-17-2007 01:46 PM |
"operating system held off interupts for too long" | alarm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 07-02-2004 01:10 PM |
"Operating system held off interupts for too long | Jonathan Grimes | General Discussion | 2 | 06-28-2004 08:32 AM |
