Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 08-23-2017, 04:39 AM
magentaS magentaS is offline
Default Mbox 2 block other USB devices
Hi there!
I have Mbox 2 sound card that I run on Windows 7. I was wondering why is it blocking other USB/midi device? I tried connecting my midi controller Allen & Heath K2, but when Mbox is plugged in, the K2 doesn't work. K2 only works when Mbox is not plugged in, and I need both of them so I could have my monitor speakers and midi control at the same time.
K2 has built in sound card, but I only want to use it as MIDI controller.
This happens even if mbox isn't default sound device.
Hope that I will get some kind of solution because I don't know how to solve this on my own.
Thank you in advance.
Old 08-24-2017, 02:12 PM
albee1952 albee1952 is online now
Default Re: Mbox 2 block other USB devices
It may be that the Mbox is using up all the available power from that USB bus. Usually, USB ports are in pairs, so try moving the K2 to another USB port, or try using a powered USB hub to feed the K2(assuming the K2 is also bus-powered)
Do any MBox devices have adjustable pre-amp input? tbessie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 01-31-2011 05:25 PM
Mbox Whines with External devices. hue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-18-2009 06:45 PM
devices to hook up through mbox luvzluv 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-24-2007 06:45 PM
Mbox 2 /PT LE 7 not showing up in audio devices tkrinor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-01-2006 09:50 PM
Problems: Mbox + MIDI USB devices? erhagan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 09-11-2004 08:19 AM
