Old 08-05-2017, 10:53 AM
EricDolphy101010 EricDolphy101010 is offline
Default Custom Bank question
Hi there,
is there any way to map a single knob to multiple parameters of the same plugin with different settings?
For example:
Knob track 01 -> Comp01 -> threshold from -20db to -15db
Knob track 01 -> Comp01 -> ratio from 1.5:1 to 6:1
Knob track 01 -> Comp01 -> Makeup Gain from -20dB to -12db
I've tried to dig a bit into the manual and over the internet but didn't find anything similar.
What I want to do is basically have more than one parameter attentioned on a single knob.
Any suggestion, thread, referral to the manual is highly appreciated!
Thanks for you time!
Old 08-05-2017, 03:10 PM
Default Re: Custom Bank question
I've found that Plug-in Mapping option on PT and I've tried to use it with the S3 but under View menu, I don't have the Plug-in option and so the plugin mapping field doesn't appear in any plug-in
As reported on the manual the control surface should be connected and installed properly as it should be on my system.
Anybody with similar experiences?
Old 08-06-2017, 01:53 PM
made made is offline
there is no plugin mapping on the S3
even if there would be an mapping option like there is with the Command 8 something like you want won't be possible.
You have to use a different DAW like Reaper to do that.
S3 only works like and "Artist" controller on Reaper, but you can do complex parameter mapping.
Mac Studio, 32GB, PTHD2022.7, OS 12.5.1, S3, Transport, (EuCon 2022.4.0.78)
LIO-8
BlackmagicDesign UltraMonitor3G
Reaper 6.66, Fireface UCX
MacbookPro M1Pro PTHD2021.12 MacOS12.1
MOTU 24Ao AppleTB3toTB2->AppleTB2->Ethernet->AVB
Old 08-07-2017, 02:50 AM
J-S-Q J-S-Q is offline
FYI, you can do plug in mapping with Cubase/Nuendo, and also have full Eucon functionality.
Creating a Custom Sound Bank in PT (for easy access to my sounds) johnbarnesiii Virtual Instruments 5 06-03-2015 12:20 PM
Creating a Custom Keyboard Sound Bank johnbarnesiii Pro Tools 10 8 07-03-2012 01:35 PM
Bank D on SC48? Future Custom Bank perhaps? digidesigner VENUE Live Sound Systems 1 01-11-2010 07:20 AM
Max Custom Fader Bank JKD99 ICON & C|24 6 11-23-2009 09:27 AM
Import custom faders bank Pythagor ICON & C|24 2 04-28-2006 03:04 PM
