Old 04-11-2012, 02:22 PM
davemeasom davemeasom is offline
Default No Input Signal - Mbox 2 - Pro Tools 8.0.5
Hi
I have recently installed my mbox 2 and pro tools system which is now up and running! However when i plug my guitar into the D.I slot i can't see any signal on the mix window or home window! The frustrating thing is i can hear everything in the headphones!! i have tried input only monitoring, switching the guitar cable into the input 2 slot and its really frustrating if anyone has any answers please come forwards
thanks in advance
Dave
Digi-Design Mbox 2
Pro Tools 8.0.3 Cs
Computer
Model : Packard Bell IMEDIA A3317
Mainboard : Packard Bell PBGL00
BIOS : AMI (OEM) PBBGL00.P07 01/08/2009
Total Memory : 2.75GB DIMM DDR2
Processor : AMD Phenom(tm) 8550 Triple-Core Processor (3C 2.2GHz, 1.79GHz IMC, 3x 512kB L2, 2MB L3)
Chipset
Memory Controller : NEC RS690 Host Bridge 199MHz FSB
Memory Controller : AMD F10 Athlon
Old 04-12-2012, 03:25 AM
stickboymusic stickboymusic is offline
Default Re: No Input Signal - Mbox 2 - Pro Tools 8.0.5
Don't know how new you are to protools
so the most obvious answer is -
Have you opened a new mono audio track, set the input to anologue 1 or 2 depending on where you are plugging in and clicked the R button on the channel to arm record?
Old 04-12-2012, 08:47 AM
I am new however I have ensured that the channel input is one and the output states 1 + 2, I also have armed the track pressing the record button! I did get some signal through one time however it buzzed and clipped constantly then nothing more came of it! I can hear the signal through the headphones also
Digi-Design Mbox 2
Pro Tools 8.0.3 Cs
Computer
Chipset
Old 04-12-2012, 03:35 PM
albee1952 albee1952 is online now
Maybe the Mic/DI button needs to be in? Or maybe the monitoring software is not set correctly(I don't use an Mbox so I can't offer advice there).
Old 04-12-2012, 05:34 PM
Top Jimmy's Avatar
The Mbox 2 has the mix knob on the front of the unit. One side of the knob is the output from Pro Tools and the other side is the input monitoring. Blending the two is how you get low latency monitoring of the input with what is coming out of Pro Tools. Make sure the knob is at 12:00 so you are assured of hearing both.
James Cadwallader
Old 04-12-2012, 08:04 PM
Just in case nobody covered this typical newbie goof, your guitar should be recorded to an AUDIO track and not an INSTRUMENT track(which is for Virtual Instruments and midi)
Old 04-12-2012, 08:50 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default
Wasn't that the original Mbox ??? My Mbox2pro didn't have that mix knob
Daniel
Old 04-12-2012, 10:20 PM
Top Jimmy's Avatar
He clearly wrote Mbox 2 (not pro) which did/does have the mix knob.
James Cadwallader
Old 04-14-2012, 11:53 AM
I have tried all of the above and so far nothing has changed?
Digi-Design Mbox 2
Pro Tools 8.0.3 Cs
Computer
Chipset
Old 04-25-2012, 07:52 PM
thermos123 thermos123 is offline
Heyo,
My M-Box 2 Mini is doing the same thing. Instrument plugged into line input 1, inputs are correctly assigned to 1-2, track is armed. I am hearing signal from the soundcard, but not through Pro Tools. When I do arm the track I get a overdriven reading on the VU meters, but no sound. Just a click when I arm the track. Any solutions please!?!
No Input Signal in PT 8.0.4 or MBox mini 3 Chazz_IS_God Pro Tools M-Powered (Mac) 3 07-10-2014 02:53 AM
MBOX 2 - Weak Input 2 Signal grhufnagl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-15-2008 11:32 AM
Problem with low input signal using Mbox tdellaringa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-27-2006 08:57 AM
MBox 2 Problem. NO Input, but signal !?!?! nowinner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-29-2006 02:58 PM
NO INPUT SIGNAL/ MBOX jkereny1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-01-2002 11:09 PM
