Can I record with insert effect?
I have a large archive job involving recording many stems to files. All the files need to be limited to -10dB for broadcast purposes.
They way I have it set up is that the buss for each stem has a send to a track which acts as the record track. I sometimes ride the busses up if needed so I can't add the limiter to the busses. What would be great is if I could insert the limiter on the actual record track and have the result recorded into the file. This would save time applying the limiter as an AudioSuite process. I know I could create a set of aux input strips, put the limiters on those and send them to the record tracks but this seems like creating lots of extra tracks in projects with many tracks already Does anyone know if it is possible to record with an insert? Thanks |
Re: Can I record with insert effect?
Why don't you insert the limiter on the audio track where your audio is?
It's quite a complex TV dubbing mix setup and I have to deliver Dialogue, Voice Over, Atmos and Music separately. And these stems must add up to the final mix to make reversioning of the programme as easy and cheap as possible for the production company. Thanks
Maybe if you explain how you route things it would be easier to fully understand.
ok so I have maybe 6 tracks with dialogue that go to a dialogue buss. If having done the first mix pass I want to relatively lift the dialogue I just need to ride up the dialogue buss - also this is a good way of getting more level if a scene was recorded too low. The same goes for music (gets summed to a bus), Atmos&FX and Narration (sometimes more than one narrator). These busses/stems are all summed to a mix buss which is limited for the delivery of the final 2-track mix. That all works fine.
When it comes to delivering international stem mixes I want to limit post-buss fader - downstream of any final rides I do any stem, because I need the international stems to be limited to -10dB. If I were to limit the dialogue tracks themselves, or the dialogue buss for that matter, any rides on the buss would make the international track rise up to illegal levels. One thing though, do you know whether recording with an insert on the track is possible at all? thanks for your reply |
Wait, do you mean that you already have auxes where the audio comes in? Then insert plugins there, they will record to the audio track.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Hi Ben
You just quoted me but left of the post I think - were you going to shed some light?! Thanks |
What I would do, is bring your sources into Aux tracks, assign their outputs to stem busses, and use a Master fader for each stem bus output. Put your multi-channel limiters on the Master faders, and you will limit going to the record tracks. Assign your record track outputs to your monitors and you can listen to the combined stems as you record.
Save early and often! (or once a day whether you need to or not...) |
Right you are, sir, I stand corrected! But they still won't be recorded when placed on a record track since they process the audio on playback. Thanks.
hardware effect insert | rorez | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 03-13-2010 10:51 PM |
Using REaktor as an insert effect | Ford | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-15-2006 11:49 AM |
External Effect as Insert | Cayce | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-04-2005 03:27 AM |
How do I use the Line 6 Pod as an insert effect? | jonny munka | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-07-2004 11:52 AM |
How can I insert a hardware effect into my master track? | Animal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-14-2002 01:42 PM |
