Old 01-26-2004, 06:32 AM
Spliff Spliff is offline
Default Help-Amplitube automation
Hi everyone,
Has anyone had any success automating the wah level? I`ve tried everything and I just can`t get it to work. I`ve done a search on these forums but nothing has worked. I`m using PT 6.1, amplitube is from the ikmultimedia bundle, version le. Thanks in advance.
Old 05-17-2004, 06:10 AM
Silent Noise Silent Noise is offline
Default Re: Help-Amplitube automation
I guess my question is the same. How does one automate using amplitube (particularly the wah level).
Old 05-23-2004, 10:35 PM
laaaakes5 laaaakes5 is offline
alright it took me awhile to get the hang of this. first you have the recording of the track that you want to ad the automation to. in your cases the wah. you go into the amplitube effect window and click auto. a new box opens withing protools. with a list of names like gain, overdrive,post eq,reverb, stuff like that you click on the desired item to automate. and click add. for wah add all the items that are changed. in amplitube make sure the wah is on manual or just ON i think. before playback of the track under the track name, there is a box that by default says READ. click on this and a drop down menu will apear. click WRITE. ( which i think is the lowest one. i'm doin this off memory) play back the track and change the parameters durning playback. playback again to hear and see the wah change. if you click on the far left side of the screen in pro tools right below the track name on waveforms and change it to plugin - then wah you will see the lines with in the track. change these to fine tune the sound perfectly.
hope that helps you all. if u guys need any help or i didn't explain something email me at [email protected] and i'll help you out.
Old 09-13-2021, 12:52 PM
FRUGiHOYi FRUGiHOYi is offline
I don't know if it's because everyone who writes these automation directions is using another version of Pro Tools than me (and all the other people saying "it just doesn't work") or what, but THERE IS A STEP MISSING from these directions. After you add the parameters you want to change via the AUTO button on Amplitube, you have to right-click the Amplitube plugin in the track in question in Pro Tools and choose "Automation Dialog." There you can see the parameter and add it to the list on the right side. Click Ok and voilà, you can click on the "Playlists/Waveform/whatever you currently have selected" button, choose the parameter and draw it in. Or you know, use the Write function and do it intuitively during playback if that's what floats your boat.
To summarize:
  • Open the Amplitube plugin, click AUTO (all the way on the bottom right), find the parameter you want to change and add it to the list on the right.
    OR to do it in a simpler way:
  • Right-click the parameter you want to change, Assign Automation and put it in one of the parameters
    Whatever you chose above, you can now proceed as follows:
  • Right-click the Amplitube plugin in the track in question in Pro Tools and choose "Automation Dialog." There you can see the parameter and add it to the list on the right side. Click Ok.
  • Voilà, you can now click on the "Playlists/Waveform/whatever you currently have selected" button, choose the parameter and draw it in. Or you know, use the Write function and do it intuitively during playback if that's what floats your boat.
Amplitube + automation Carl Kolchak Pro Tools 10 8 11-16-2013 07:36 AM
MIDI Automation to Audio Track Automation BBKBB Pro Tools 10 6 11-28-2012 01:56 PM
Protools Automation to AAF Media Composer Automation TommyT Pro Tools TDM Systems (Mac) 1 08-10-2011 01:40 AM
Convert MIDI automation to audio automation jnash 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-21-2010 03:28 PM
Amplitube Automation!?! Benjamino 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-05-2007 03:59 PM
