Old 08-07-2002, 11:20 PM
whiterabbit whiterabbit is offline
Default using outboard gear
This is the first time I've tried to hook up outboard gear to the digi001 and I can't get. Basically could some one tell me the signal path. I'm using a multi-fx unit and I would like to us it on one of my audio tracks but I don't understand if I need to use an Aux track or not.
Help Please!!
Old 08-07-2002, 11:29 PM
milesyoung milesyoung is offline
Default Re: using outboard gear
If you are routing the whole signal through an external unit, select the appropriate output on the channel strip (rename your ins and outs with meaningful names in the "I/O Setup" for an easier life).
Then add a new AUX track and set the input of the AUX track to come from the external unit. Then you'll hear the resulting signal.
If you don't want the whole signal to go through the external device, leave the output of the track alone, and select the external device/Digi001 OUT in one of the Sends (underneath the plugins). You'll still need the AUX track to monitor the returned signal though.
Miles Young
Old 01-30-2003, 05:15 PM
bwherry bwherry is offline
Originally posted by milesyoung:
...(rename your ins and outs with meaningful names in the "I/O Setup" for an easier life).
Does renaming I/O paths in PTLE (001) work for you guys? I just tried this and it "just won't take." I gave In1, In2, etc. each a name and exported that to "Last Used.ptio" but when I import that I/O setup into my session, the names don't show up. Am I doing something wrong?
Thanks in advance,
Brian
Old 01-30-2003, 06:46 PM
da BaSsTaRd! da BaSsTaRd! is offline
try it again, but when you export, give it a different name, like "brians io.pio". then, if you create a session and your i/o setup is not the way you want it, go to setup > i/o setup and import "brians io.pio".
i love my apple iPhone!
Old 10-29-2021, 11:43 AM
K Roche's Avatar
K Roche K Roche is online now
Help Please!!
Lets see if I can help .. First what version of PT are you using ? Not sure of way back when ,,, but in most of the more recent versions ?
No you do not "need" to use an aux track you can use it on any track as a HW insert, accessed from the inserts section of the track in the I/O selection of the inserts drop down
But might want to put it on its own Aux track as a parallel effect for multiple tracks, which is how I do it
Physically you simply connect it to one (or two if a 2 channel unit) of the 8 channels on your 001 So if it is a 2 channel unit , say 5-6 of your 001---- go from the 001,, 5-6 outs to the ins on your HW unit, and then from the outs on your unit,, to the 5-6 ins on your 001
So here is my set up with my HW compressor on 5-6 and renamed 3U and my HW reverb renamed M7
both are on there own Aux tracks,,, the reverb so I can send multiple tracks to it and the Comp as a 2 bus compressor on my 2 Mix track which the entire mix routes to before going to the main 1&2 outs (which I have renamed Stereo Mon)
So here you see they are in the inserts sections of their Aux tracks the M7 3rd from right and the 3U second from right
Here is where they are accessed from the inserts -I/O section dropdown , this is the inserts for the M7 track and at bottom you see i/o selection in blue,,, and M7 is checked
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 10-29-2021, 12:57 PM
Oops K Roche, you are replying to an old post from 2002. Sadly this is what happens when folks reactivate/spam old threads with irrelevant questions (the spam post was removed by mods).
Old 10-30-2021, 06:45 AM
K Roche's Avatar
Ha ha well I am old and for go to look at the date so there ya go
System :
Enjoy the Journey
.... Kev...
Old 10-30-2021, 04:24 PM
On the plus side, I think you now have the record for the oldest thread to resurface
ADC with outboard gear? basslik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-09-2010 06:33 PM
Anybody using outboard gear with PT ? Blackers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 09-08-2010 04:23 PM
where to put outboard gear wayner ICON & C|24 0 09-15-2005 06:19 PM
Using outboard gear with 002 Laboratory 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-29-2003 06:05 PM
Outboard gear??????????? adspi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-20-2000 02:38 PM
