Old 09-21-2021, 10:24 AM
Zergei72 Zergei72 is offline
Default Digidesign DIGI-002 / Behringer Virtualizer 3D FX2000 - Routing
So, I'm pretty lazy reading the manual ...
How to do the routing ?
For e.g. Mic goes to DIGI-002 Input 1, but from there to the Behringer and back to the DIGI-002 ; quite not so sure .
Please simple details . (((:::
- Z -
Old 09-21-2021, 11:19 AM
Default Re: Digidesign DIGI-002 / Behringer Virtualizer 3D FX2000 - Routing
Ultimately, you SHOULD read the manual. If the Behringer has SPDIF IO, I would create an output from PT that goes out via the 002 SPDIF output. Return the Behringer on the SPDIF input(to a stereo AUDIO track set to Input mode; when your mix is done, record the effect) and if that input is not already available in the IO, then add the input path. If the Behringer is only analog IO, the method is pretty much the same. Having said all that(and I do encourage you to learn how to do this stuff), unless there is some spectacular sound in there, plugins will likely do the job as good if not better, and avoid all the extra hassle. Its much the same as someone jumping thru hoops to insert a cheap DBX or Alesis compressor because they believe "hardware" is just better(when it very often is not better). There are plenty of really good reverb plugins for $100 or less(IK Classik Reverbs for example), really good delay plugins for $50 or less(Waves H-Delay on sale?) and pitch doublers(Soundtoys Microshift). Food for thought
Old 09-22-2021, 03:39 AM
Well I've almost got the set up done ;
But something's still not correct ...
I can monitor the fx on the Behringer, but I hear the backing track / music going to the Behringer also .
- Z -
Old 09-22-2021, 03:37 PM
Gotta be a routing issue. Maybe that's another good reason to skip the idea and stay with plugins
How can I change the default track routing ? Talisker Pro Tools 2020 24 02-19-2021 01:58 PM
Basic Routing Folder Default Jkoebe Pro Tools 2020 19 02-08-2021 08:17 AM
HELP! Is there a preference in PT to change default IO subpath routing creation? bassmagnetic Post - Surround - Video 1 08-09-2017 04:03 PM
Is bpm sync possible with Behringer Virtualizer pro? Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-01-2008 10:51 AM
Routing channels from Behringer 1604 to 001 saavadra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-03-2002 05:01 PM
