Old 09-10-2021, 01:16 PM
Zergei72 Zergei72 is offline
Default PT LE 6.4 / XP SP3 / DIGI002 Not Seen
Yeah I know it's pretty retro, but whatever ...
I've got my OS all set up (Windows XP x86 SP3) .
REAPER (Latest version 6 sees my DIGI 002 - Rack), but when I try to launch PT 6.4 (all updates installed cs6 and cs9 as well) I get this ;
Unable to locate Digidesign Hardware and so on ...
I have the latest legacy pace / ilok - drivers installed as well .
I'm using a VIA - Two Port PCI FireWire Card .
Some help, please .
- T -
Old 09-10-2021, 01:31 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: PT LE 6.4 / XP SP3 / DIGI002 Not Seen
002 should be working on XP SP2
Janne
Old 09-10-2021, 04:29 PM
The Weed's Avatar
The Weed The Weed is offline
iLok not required, it's the 002 that authorizes Pro Tools. I'd uninstall anything iLok as a test.
As said above, the 002 and PT 6.4cs9 are qualified for Windows XP SP2: http://akarchive.digidesign.com/compato/xp/64/002/
Grasping at straws, go to Control Panel>Sound and make your onboard soundcard the default for Windows sounds/audio and disable any instance of the 002 under the Playback and Record tabs.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Digi002 works on Mac, not on Windows. ANOTHER Digi002 works on both hammerfied 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-20-2016 02:38 PM
Power Mac Digi002 rack and Digi002 with faders jpkorell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-08-2011 11:17 AM
Pro Tools & Digi002/Digi002 Rack/M-Box Kavie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-09-2005 02:33 PM
DIGI002 powerpop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-29-2003 05:11 PM
Digi002 Rack shipping with Digi002 plugin pack? Vaphoron 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-22-2003 02:38 AM
