Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 04-28-2020, 03:52 PM
davision davision is offline
Default How to access old MBox/PTMpowered 8 audio without interface?
Just keeps saying Hardware Insert missing error (of course it is as I haven’t used the mBox in years) I have a Focusrite plugged in at the moment - no problem recording new audio but any audio recorded via the mBox interface is no longer showing up in the audio files folder of a particular session, so I can’t even manually link them as they aren’t there.
Anyone else know how I can rescue all these audio files/where to find them? cheers
Old 04-28-2020, 04:11 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: How to access old MBox/PTMpowered 8 audio without interface?
Hi, Have you checked your Disk Allocation? Could be recording to a different location than your session.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (3)
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 04-28-2020, 04:20 PM
The Weed's Avatar
The Weed The Weed is offline
You can't open an MPower session without the Mbox or, really, AFAIK, an M-Audio interface. Can't you just import the audio from the old session folder?
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 04-28-2020, 05:28 PM
Chris, thanks for responding but it’s actually for older pre recorded files
I think The Weed has answered my question - the audio files are completely missing from the folder, so I’ll have to drag out the old hard drive from storage and try and recopy
Just weird that the files are missing inside the Audio Files folder, I could understand if I mistakenly didn’t copy the Audio Files folder etc. anyway, cheers all
Old 04-28-2020, 05:34 PM
JFreak's Avatar
JFreak JFreak is offline
Anything pre-PT9 requires proper interface. Only PT9 and later can work without.
Janne
Can't access audio interface. Andresen Getting Started 2 01-06-2018 09:13 PM
Mbox 1 - Recommend New Audio Interface gerarddaly Pro Tools 9 2 05-30-2011 09:56 PM
Using another audio interface like an Mbox? Blueswah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-08-2010 10:15 AM
Should I keep my mbox 2, or get a m audio interface Mr.R23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-27-2009 03:36 PM
Audio interface for MBox / PT8 LE / Intel Mac trevinho MIDI 1 04-20-2009 01:41 PM
