Old 04-21-2020, 05:26 PM
bonzerboy bonzerboy is offline
Default Bounce or Print
I use several VI and find issues sometimes,,, so instead of having several VI open want to make audio tracks.. is it better to print or bounce the track,
Would this also apply tp printing or bouncing a final mix before mastering?
k
Wow am I groovy or what
Old 04-21-2020, 05:37 PM
Top Jimmy's Avatar
Default Re: Bounce or Print
Why not freeze?
Otherwise...
Everybody Just Bounce!
James Cadwallader
Old 04-22-2020, 01:18 AM
cwsand's Avatar
cwsand cwsand is offline
I prefer to Commit Up To the VI plugin so that I'll have an audio track to work with - mainly because I just prefer working with actual audio tracks when mixing. Plus, it's good to have the VI printed in case for whatever reason the VI becomes unavailable at some point. You still have the MIDI/Instrument track you can go back to if you Commit, the only downside is that if you make changes to plugins after the VI or have automation on the audio track, you have to make sure to copy the changes back and forth.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 04-22-2020, 05:24 AM
So is there better quality if you print then bounce or the vice versa ?
Old 04-22-2020, 06:09 AM
Sardi Sardi is offline
No.
It’s just workflow. Sound is the same.
Old 04-22-2020, 07:21 AM
thanks,, I thought so but wasn't sure because someone told me printingthe track in real time was the wat to get all your automation correct and that bounce could mess up automation.
Old 04-22-2020, 12:36 PM
cwsand's Avatar
thanks,, I thought so but wasn't sure because someone told me printing the track in real time was the wat to get all your automation correct and that bounce could mess up automation.
I have had VI's audio messed up when bouncing a mix or even freezing or committing - like glitches in the audio or tails cut off - another reason I like to commit them to audio and make sure the audio track is perfect so that you don't have to worry about it later.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Bounce or Print in a Master Session with PT kalony Tips & Tricks 2 04-13-2017 02:29 PM
Mix, bounce to disc or print to audio chan. JimmyM Pro Tools 11 11 03-24-2017 01:24 AM
PRINT vs offline bounce stormmusic Pro Tools 11 5 01-31-2016 05:37 PM
Speed of Song after bounce/print to mp3 eekamouse Pro Tools 11 9 12-18-2015 08:03 AM
Print/Bounce Tracks with Plug ins gjohung 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-23-2006 09:19 PM
