Pro Tools/Komplete 11 HELP
So I've had Pro Tools 10 for a while now, and recently updated to the latest version of 10 (which is 10.9.3 I believe?). I bought Komplete 11 yesterday and installed/updated everything that needed to be done, but when I load PT a few of the plugins do not show up. Absynth, Massive, FM8, Battery 4 and some others all loaded fine and I can use them without a problem. But I can't figure out how to get PT to recognize Kontakt 5 (which I was most excited about) and Reaktor 6 for some reason. They work as standalone applications on my iMac but aren't recognized in Pro Tools.
I did check the plug ins folder (Library>Application Support>Avid>Audio>Plugins) and they are in there. So frustrated right now. Please help. |
Re: Pro Tools/Komplete 11 HELP
This is what happens when there's no system info at hand - time is wasted and you may be given wrong info to solve your problem. |
Sorry should've stated I'm on Mavericks 9.5. Is there no way to downgrade my Kontakt/Reaktor to be useable on Mavs/OR 10.3.10. It came with Reaktor 5 also which shoes in PT but won't allow me to drag samples in because the newer 6 is installed also. |
Options: none that are pretty. You could upgrade to PT11 or 12. You could try and find an older version of Kontakt 5 but - if you also have an updated Kontakt Factory Library (not every Kontakt library that comes in Komplete just the little part called Kontakt Factory Library) it will not work in older versions of Kontakt. The rest of the libraries in Komplete will work as will third party libraries. Going to another OSX like Yosemite or later is also a non-starter for the reason I mentioned earlier. Trying to host the au or vst version of Kontakt inside Blue Cat Patchwork synth version won't work either. It all boils down to the fact that K5 latest is not a 32 bit application. Goes to show that having the latest version of anything might not be a good thing. |
Pro Tools 12 with NI Komplete Kontrol | randb1 | AAX Plug-ins | 7 | 05-27-2015 02:20 PM |
Problems upgrading Komplete 8 to Komplete 10 Ultimate in Pro Tools 10.3.9 | Freddysdead | Pro Tools 10 | 17 | 02-12-2015 01:46 PM |
Pro Tools 10 and Komplete 8 | himynameisdustin | macOS | 3 | 03-28-2013 12:42 PM |
How to add Komplete 8 Ultimate into Pro Tools 10 LE | Ryan Tunis | Pro Tools 10 | 3 | 02-02-2012 02:13 PM |
Pro tools expansion vs Komplete 6 | badvibration | Virtual Instruments | 52 | 08-22-2010 04:54 PM |
