Old 04-27-2017, 06:50 AM
David Khositashvili David Khositashvili is offline
Default Error -6101 when recording
Hi, need your assistance.
When I record I have Error -6101. Recording stops.
I made a clean install of OS, Protools and, hardware driver, but no luck.
Here is what I use:
MacBook Pro (Retina, 15-inch, Mid 2014)
Processor 2.2 GHz Intel Core i7
Memory 16 GB 1600 MHz DDR3
Total Number of Cores: 4
El capitan 10.11.6
Audio Interface:
Merging Hapi
With AES67 and RAVENNA connectivity.
No other software or drivers installed besides Merging.
I use additional 8 channel preamp Focusrite Oktopre MKII
I use Protools 12.7
I've made all necessary optimisations for my mac. I have latest driver and firmware version.
I record on G-drive external hard drive with 7200 rpm.
Please help me to solve this problem.
Thank you very much!
Old 04-27-2017, 02:12 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Error -6101 when recording
Hi, A couple of questions:
How many tracks are you recording at once and at what buffer setting?
How do your external drive and audio interface connect - USB 2/3, Firewire 400/800, Thunderbolt?
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 04-27-2017, 05:49 PM
tomorrowstk tomorrowstk is offline
CWSAND above has solid questions. I would like to chime in and let you guys know about my findings with the -6101 error. This error seems to occur when the drives that are getting the audio written to them are not quite able to handle the amount of data from the audio interface driver to the actual hard drive itself. I see you are recording to a 7200rpm drive which is great but another factor in the drive is the cache. Spinning drives at 7200 RPM should have a cache of 64MB or above as this plays a huge role in data transfer. PT seems to want the best performance or its error central. If you can find out if the drive that is in the external drive case has 64MB or above cache then we can move on to drivers/interface. If your system (OS, PT, etc...) is a solid state drive then you are moving in the right direction. I only say this as I have had issues in the past with my recording drives. Sometimes the drive specs can be fine but if the drive health is going downhill it can cause issues.
Old 04-27-2017, 10:40 PM
JFreak's Avatar
JFreak JFreak is online now
Why do you tease yourself with ElCrap? Sierra is the way to go...
Janne
Old 04-28-2017, 03:20 AM
I record maximum 24 channels 24/48
Buffer size is set to maximum 1024
And I don't use any plugins when get those errors.
It's USB3 connected directly to USB
Old 04-28-2017, 03:26 AM
I use exactly this drive
http://www.g-technology.com/products/g-drive-ev-atc
I think it's more than 64 mb
I have SSD in my mac and use it just for system and software
Old 04-28-2017, 03:27 AM
Merging hapi driver works with elcapitan
They didn't release it for sierra yet.
Old 04-28-2017, 03:33 AM
One more thing: I've been testing system for few days and several times I have recorded up to 3 hours (24 channels) without interrupting.
So, it doesn't repeat often, just sometimes.
Old 04-28-2017, 04:35 AM
Wizzoboy's Avatar
Wizzoboy Wizzoboy is offline
6xxx errors are usually driver related.
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - 3 screens - JBL Monitoring.
Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 546.01 - 2 x Internal Samsung 860 EVO SSDs, and MSATA card - Davinci Resolve Studio 18.6.4 - 3 screens - Blackmagic Speed Editor - MK1 Presonus Faderport - Canon C100 mk2 - Atomos Ninja 2 - Zoom H2n
Old 04-28-2017, 11:23 AM
So, there is a chance that merging drivers are not compatible with protools 12.7?
HELP! -6101 errors while recording on PT 11.0.2 OS 10.8.5 neil_mcdermott macOS 3 10-29-2013 10:17 AM
6101 error on bounce (not while playing or recording) pkm macOS 11 09-22-2011 04:55 AM
Error Message 6101 when recording and playback Mattslash Pro Tools M-Powered (Mac) 2 10-07-2010 03:13 AM
Error 6101 while recording to Internal Hard Drive on Mac Pro KeithKenny Storage Subsystems 2 02-10-2010 09:21 PM
