Old 04-16-2017, 10:15 PM
[email protected] eltoncollins@icloud.com is offline
Default MIDI Notes cut off during with Record enabled
Hey folks,
When I have record enabled I have MIDI notes cutting off when I try to over dub or even just play the track. Almost like trying to play chords on a mono synth.
I am sure I am missing something and your help will be greatly appreciated.
Thank you in advance.
Old 04-17-2017, 04:48 AM
Default Re: MIDI Notes cut off during with Record enabled
Originally Posted by [email protected] View Post
Hey folks,
What are you using as a MIDI controller? If it's a synthesizer then try turning off 'local off' on the synthesizer. If it's just a controller keyboard with no sounds of it's own AND you're using traditional 5 pin MIDI connections disconnect the cable that goes between the MIDI out on your MIDI interface to the MIDI in on the keyboard. This might be a MIDI loop issue.
Jack
QAPLA!
Old 04-19-2017, 11:27 PM
Hey thank you so much for the advice. Turning global off seems to have done the trick. I'll keep checking it.
Thanks again.
No sound from MIDI Keyboard when Record Enabled is on RachaelM Pro Tools 11 3 04-17-2014 11:31 AM
MIDI record enabled and found but wont record BCRich 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-23-2010 12:51 PM
Recording Midi notes and keeping existing notes during record Sherbert99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-15-2008 09:40 AM
MIDI Notes disappear when real time properties enabled BGee Pro Tools TDM Systems (Mac) 5 08-11-2007 09:42 AM
MIDI thru without Record Enabled. Dog BBQ Pro Tools TDM Systems (Mac) 2 10-21-2000 12:23 AM
