Re: Aphex Vintage Aural Exciter
Thank you people, interesting ideas.
Using Aphex Vintage Aural Exciter for vocals in the project I am mixing now. Just as an insert, to make vox more lively. In my case, what worked for me is DAW HPF -> Waves Vocal Rider -> CLA-2A -> CLA-76 -> Aural Exciter -> DAW EQ -> Waves H-delay. I like this chain. |
Actually, I'm a fan of doing Subtractive EQ -> Enhancer/Harmonics -> Compression -> Additive EQ
I like to remove some of the "nasties", enhance the desirable, compress it to bring out out a bit more and boost a little to taste. Depending what the mix needs. Not just with the Aphex, which is a great unit by the way, but with anything I use to generate harmonics in general. It's good to have several enhancers doing different things in my opinion the mix is less likely to sound "hyped" and harsh in some instances. |
Way to do too, it depends if you want to compress it with harmonics or not.
Also great as a squasher on a parallel processed drum group. Smash and add to taste.
Aphex aphex big bottom pro/aural exciter bundle tdm rtas | Tank | Buy & Sell | 0 | 06-10-2013 05:45 AM |
Waves Aphex Vintage Aural Exciter® plugin | bacchus40 | Pro Tools 10 | 4 | 08-01-2012 07:02 PM |
Q : Aphex Aural Exciter TDM | Aquarius | Pro Tools TDM Systems (Mac) | 4 | 03-17-2008 10:12 AM |
Aphex aural exciter | Ricco | Tips & Tricks | 4 | 09-02-2000 12:02 AM |
Aphex Aural Exciter | AdamFrick | Pro Tools TDM Systems (Mac) | 1 | 11-12-1999 01:36 PM |
