Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 09-25-2014, 08:23 PM
RainyDaze RainyDaze is offline
Default Issues with Fast Track Solo
Greetings,
I purchased Pro Tools 10 a while ago and was initially using the TASCAM US-1800 audio interface. A few days ago, the interface stopped working after recording audio for a song and would not allow me to reload the drivers. Frustrated that I could not get any support, I decided to purchase a Steinberg CI1 audio interface, but ended up taking it back after it played clicks, pops, and stuttering audio. I ended up returning the interface and purchased the Avid Fast Track Solo. After installing the drivers, I opened up a project that played fine for about 30 seconds before blasting static through the speakers. Sigh. Since then I've reinstalled drivers, reinstalled Pro Tools, switched USB ports and cables, disabled programs running in the background, and even tried drinking a beer while watching "How to Get Away with Murder." Admittedly, I haven't updated my PT version because 1.) it took almost a week to get it working with the TASCAM US-1800, and 2.) the computer running Pro Tools isn't connected to the Internet because there's an issue with the wireless adapter...basically, there isn't one.
Has someone experience this issue and found a solution? Oh yeah...I'm also aggravated that I can't contact customer support without having to fork over more money, but I suppose there's a really good reason for that...��
Old 09-29-2014, 11:29 AM
JoelG's Avatar
JoelG JoelG is offline
Default Re: Issues with Fast Track Solo
Can you post your full system specs?
What driver version are you running?
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 12-13-2014, 09:53 AM
rock12's Avatar
rock12 rock12 is offline
Hey JoelG does fast track duo work with maverick? Gonna use this to record while out of the studio on my new MacBook Pro 15". But if it doesn't work I'll probably have to get a new small interface that works.
Old 12-15-2014, 10:01 AM
JoelG's Avatar
Yes, it should work fine with Mavericks. The FT Duo is a class compliant device and does not need drivers downloaded to work with Macs.
http://avid.force.com/pkb/articles/d...ck-duo-drivers
Joel
Jam Space:
Home:
Rig:
Old 12-15-2014, 05:02 PM
rock12's Avatar
Ok cool! Thanks!
Old 12-17-2014, 09:34 AM
nOteam nOteam is offline
Guess the problem accures at my studio to, when the iLok and FastTrack "Control" software is not open, and the same if the interfaces is crashing with another sound device on the OS/iOS. Try to activate only the avid hardware, and try to make sure the iLok is online (you need internet connection) Hope it helps, couse my eardrums really almost popped a couple times!
Fast Track Solo/Duo And PT 11 GTBannah FireWire & USB Audio Interfaces (Mac) 10 01-16-2015 08:26 PM
fast track solo and Yamaha hs5 sub14 FireWire & USB Audio Interfaces (Win) 2 06-25-2014 08:21 AM
Fast Track Solo RRIVERA2012 Pro Tools Express on Windows 3 06-24-2014 07:26 AM
UA pre amp with fast track solo SidBarone Third Party Interfaces 2 04-22-2014 11:29 PM
Fast Track Solo - no output Elnico50 FireWire & USB Audio Interfaces (Mac) 0 12-17-2013 05:01 PM
