Auto-Tune Evo Latency Issue
I lay down a vocal track, and insert my Auto-Tune plug-in. Everything's dandy, however the processed vocal is now slightly dragging.
Any solutions? Sent from my Droid using Tapatalk
Mac Mini OS X 10.8.5 2.3 GHz Intel Core i7 16 GB 1600 MHz DDR3 Pro Tools 10, 003 Rack, NI Maschine www.youtube.com/firsty33 |
Re: Auto-Tune Evo Latency Issue
Autotune Evo has alot of latency compared to the previous version (v5).
You have three options. 1) Upgrade to PT9 and use the automatic delay compensation function. 2) Manually nudge the audio to the left to compensate for the latency. 3) Insert the avid/digi delay plugin on all tracks except the autotuned track. I did number 1 and would reccomend that. |
I'll give you one more solution(that's free). bus the vocal to a new track and record it. Remove the AutoTune insert. Then using the original as a guide, nudge or drag the new audio into alignment. Hint, use Tab to Transient to find the exact time of the first word of the original, and move the new audio to the same time.
Auto Tune 7 is even worse.
If you're going to be working w/ plugs that introduce delay, you should either, 1.) Upgrade to PT9 or 2.) look into Mellomuse ATA
http://www.mellowmuse.com/ATA.html It takes a while to figure out, but once you do, delay comp isn't an issue any more.
5K Retina 27" (2020) iMac OS 13.6.5 Ventura 3.3 GHz 6-Core intel Core i5 AMD Radeon Pro 5300 4 GB 64 GB 2667 MHz DDR 4 Internal 2TiB SSD Pro Tools 2024.3 EuCon 4.8.6.41 / 2023.11 UA Luna UAD 11 UA Apollo Twin X Avid S1 / Fire10 - 21.8.1.0 PreSonus DigiMax FS 8-input ADAT Dynaudio Monitors PreSonus Temblor 10 Sub Check my Music out here: Paul G YouTube Paul G Bandcamp |
Issue with Auto-Tune audiosuite processing | Thedspeth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-18-2010 11:54 AM |
Auto-tune efx install issue? | billhartung | Pro Tools M-Powered (Win) | 5 | 03-23-2009 04:18 PM |
How much Plugin Latency does Auto tune 5 have? | Mikey Ace | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 01-08-2009 08:30 AM |
Auto Tune issue | FiveStoriesUp | Pro Tools TDM Systems (Mac) | 0 | 05-22-2004 02:41 PM |
Random Latency using Auto Tune RTAS | jamesadam3 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-18-2003 07:44 AM |
