Re: Signal generator out of phase
What are you comparing it to? When you say 'out of phase' are you possibly referring to polarity, as opposed to an actual time-based phase shift?
I recall that I once instantiated two signal generators on two seperate aux inputs (set to the same frequency and level on both), and they completely canceled. I was very surprised indeed. There were no other plugins running that could have altered the phase on either aux. The shift appeared to be 180 degrees, since the tone vanished when both were up.
Ben B |
--Jeremy |
Hey,
Yeah sorry i mean polarity. When i play it out to my phase meter its out. If i record the tone and pan it back towards mono a bit it becomes ok but i'm confused why the signal generator is playing back weird... By the way its a stereo sig gen obviously
IMDB |
Hi there!
I just check in my PT7 to Signal generators running at once with same frecuency same level. Results: every thing seems to be ok. No signal cancelation. Did you started both at the same time? |
Garrett,
does the problem manifest itself on all your sessions or just one in particular? If the answer is “all sessions,” do you create new sessions from scratch or via template? I ask these questions because whenever I encounter a corrupted PT session, it usually “features” otherwise inexplicable “phase” issues. Creating a brand new session from scratch, and then importing all tracks from the original session, always fixed the problem. IHTH.
Andre Knecht We’ll fix it in the shrink-wrap. (Frank Zappa) . |
Hey,
Andre this happens on every session irrespective of if I open a brand new session or open a template. Its pretty confusing because the mixes are completly fine its just the sig gen. Cheers
IMDB |
frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Multi-mono Signal Generator TDM out of phase !!! | mangoustine | Pro Tools TDM Systems (Mac) | 5 | 04-15-2019 04:53 AM |
Signal generator TDM out of phase.... | Kroger | Pro Tools TDM Systems (Mac) | 11 | 04-05-2009 12:50 PM |
Bug in 7.2 Signal Generator | Craig F | Pro Tools TDM Systems (Mac) | 1 | 10-12-2006 03:17 PM |
Signal Generator | Punx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-09-2002 05:56 AM |
signal generator for what use? | jinsel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-11-2002 03:01 PM |
