Old 09-22-2003, 01:43 PM
Cliffy_Boy's Avatar
Cliffy_Boy Cliffy_Boy is offline
Default Best DI for electric guitar
Mic's and cabs are unfortunately not an option for me. I'm using a POD II, I've tried Amplitube but can't get it right. I plug directly into a line-in on an 002R. I see Mesa Boogie and Marshall have direct pre's. Anyone got a solution or opinion on how I can get my guitar direct to disk without using a mic on an amp/cab? I like a controlled Overdriven rock rhythm and lead sound.
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
-HD I/O 8x8x8. -HD Omni -Avid S3
-API 2500 -API 5500 -UA 2-1176 -UA 2-610
-Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96
-Bricasti M7. -Joe Meek channel.
-Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more
-Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12
Old 09-22-2003, 02:00 PM
mlemos mlemos is offline
Default Re: Best DI for electric guitar
I've been using a SansAmp PSA-1 for years. I use it for everything from death metal to jazz and it sounds great.
Good luck,
Marc
Old 09-22-2003, 02:12 PM
Carl Fuehrer's Avatar
Carl Fuehrer Carl Fuehrer is offline
The Groove Tubes Ditto is real nice. Avalon U5 is great also.
Peace,
Carl Fuehrer
Pulsar Audio Lab
Old 09-22-2003, 03:47 PM
Cliffy_Boy's Avatar
Can I get away with using Input 1 and adjusting the trim or will I lose the guitar depth and harmonics?
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
Old 09-22-2003, 03:58 PM
You won't lose any depth or harmonics. Inputs 1-4 (line/inst setting) are high impedance, like a guitar amp, and have plenty of gain to bring passive pickups up to needed levels.
Some people think it sounds *terrible*, but it's worth a try.
Quad 2.5 G5, 4.5G RAM
Old 09-22-2003, 04:52 PM
Cliffy_Boy's Avatar
tele - have you tried the Marshall JMP-1 or MesaRectifier Preamp. Are these the real thing or amp sims like the Pod?
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
Old 09-22-2003, 05:50 PM
reynep reynep is offline
the JMP and Mesa Pre are both "real" preamps - not simulations. Im not sure if the JMP is intended for direct recording. I think that mesa pre you mentioned is though.
The avalon U5 is one of the best instrument preamps around i believe. Perfect for running into amplitube and the like. I wish I could afford/justify the expense.
Old 09-22-2003, 05:57 PM
fredsparky fredsparky is offline
You might try to get your Amplitube right. Set up an aux input track and put your Amplitube in a plug in. Send via bus to an audio input. Set your levels. You might try lowering the gain on the Amplitube for starters and also turn the gate to the right. Turn away from your monitor when you record. You should get some good sounds.
Good luck.
FS
July
MP3's
Old 09-22-2003, 06:43 PM
neatguys neatguys is offline
Also on amplitube mess with the mic positions and cabs it takes a little work but there are some real nice (and so convienent in an apartment)tones to be had .
You still cant beat real tubes though and the mesa stuff is da bomb!!
I want to track through a real nice amp miked up and my amplitube at the same time .Thats gonna be fun!
Davec 1 results,32+68 at 1024 buffer,32+ 41 at 128 buffer both 24 bit
Old 09-23-2003, 12:08 AM
cougar cougar is offline
Heya Cliff
I presume when you say you "can't get it right" with Amplitube, that you're trying to play with the plug in-line at the time of tracking?
Has anyone tried the old trick of recording the sounds of the guitar actually using a DI (along with a miked amp or some FX or whatever) on a seperate track, then subsequently applying plugs to alter the original sound?
I know that David Gilmour did this when recording the solo for "Another Brick in the Wall Pt 2". Basically, he DI-ed his Les Paul while playing through an amp, so that the DI sound was just the sound coming out of the guitar, but effected to an extent by the feed from the stack as he played. After the initial capture, he then routed the direct out of the tape machine (or a desk send) of this sound back out into the studio and into his stack (I seem to recall that he had the head in the control room, the cabinet in the studio with a couple of mics on it). On playback, then, he had the luxury of being able to dial up the best sound for the solo to suite, and a choice of mics on the cab as well ... a very intelligent approach.
Seems to me that this would be a cool way to dial up Amplitube or Line 6 settings. Anyone tried this? I'm about to do a session with a band and am gonna try exactly this technique ... I'll post the results when I have 'em.
Keep Rock-ording!
J.
[email protected]
Electric Guitar with Focusrite 8i6 DonaldM Tips & Tricks 3 08-03-2013 02:07 PM
Electric Guitar bifbangpow Pro Tools 9 2 06-06-2012 07:46 AM
How do you record electric guitar? hymns 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 07-12-2005 10:52 PM
Electric guitar q??? jeam25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-10-2005 10:14 PM
Best Mic for electric Guitar Sudsy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 26 02-28-2002 12:41 AM
